Ignition timing on a rebuilt 1991 Civic DX
Old 06-01-2009, 10:42 AM
DennisWaller's Avatar
Default Ignition timing on a rebuilt 1991 Civic DX
After completely rebuilding this D15B2 engine including replacing the timing belt I found it impossible to advance the timing by turning the distributor to reach the recommended timing setting of 18 degrees BTDC. There are three grooves in the crankshaft pulley and the shop manual recommends setting the timing at the middle groove.The maximum advance I can achieve is the first of the three grooves in the crankshaft pulley.
I suspect I have installed the camshaft one tooth too late in relation to the the timing belt but I would appreciate the advice of other mechanics before redoing that job.
This is an interference engine. However it runs well and is quiet so I don't think any of the valves have been damaged by hitting the top of the pistons. I have not driven the car since I discovered the problem with the ignition timing.
Dennis Waller
Foreign Auto Service.
Old 06-01-2009, 11:21 AM
DCRB's Avatar
Default Re: Ignition timing on a rebuilt 1991 Civic DX
from what i know one tooth off isn't enough to cause interference, but will make it run like poop. i'd double check the timing if i were you.
dem0nk1d
06-27-2012 12:39 PM
jpservano
03-23-2011 08:30 PM
lsegcoupe
12-22-2006 07:54 PM
NatedoggAZ
14
04-13-2005 09:51 AM
dr_latino999
12-02-2004 09:55 PM
Quick Reply: Ignition timing on a rebuilt 1991 Civic DX
