how often do you rotate your tires?
Old 08-19-2002, 10:18 AM
Anderson's Avatar
Default how often do you rotate your tires?
let me know how often you guys do this on daily, auto X ...etc
Old 08-19-2002, 10:19 AM
TypeR 599's Avatar
Default Re: how often do you rotate your tires? (Anderson)
look at your tires, and if you see uneven wear, rotate them
Old 08-19-2002, 10:21 AM
Bbasso's Avatar
Default Re: how often do you rotate your tires? (TypeR 599)
at that point its too late, do it at 3000 if your very hard driving and 5000 if your easy on them.
Old 08-19-2002, 10:23 AM
eviltwin's Avatar
Default Re: how often do you rotate your tires? (Bbasso)
every oil change. i mean i am sure i donthave to but i do it so i dont have to remember when i need to do it. plus i have so3 pole positions so i want them to last me as long as possible.....
Old 08-19-2002, 10:28 AM
Larkin W.'s Avatar
Default Re: how often do you rotate your tires? (eviltwin)
Every 4000 miles or so. I want the RE730's to last as long as they can. Allthough I kinda do want to burn em' up because S03's are next
Old 08-19-2002, 10:39 AM
jond's Avatar
Never. When I switch from winter to summer and vice versa, I put the better ones on the front. Thats it though. Stupid REO10's wont wear out!
Old 08-19-2002, 10:42 AM
Yell00ITR's Avatar
Default Re: how often do you rotate your tires? (jond)
I used to rotate them like every 1000 miles during autox/track season and every 3000 miles otherwise. I got just under 30K miles out of the RE010s (with some track/autox time on them!) so I must have been doing something right. Also, make sure to check pressure often.
Old 08-19-2002, 10:46 AM
Moderator in Chief
Muckman's Avatar
I rotate mine often, maybe once every other month. But they are directional so they cant be rotated far... only on the same side.
Old 08-19-2002, 10:57 AM
kkim's Avatar
every 1000-2000 miles.
Old 08-19-2002, 04:34 PM
vtec.dc2's Avatar
rotate/balance every 3,000 miles.
Old 08-19-2002, 04:46 PM
Flux's Avatar
Default Re: how often do you rotate your tires? (vtec.dc2)
after switching my tires for an autox...
Old 08-19-2002, 05:32 PM
Bbasso's Avatar
Default Re: how often do you rotate your tires? (TyPE-RON)
Go to Costco, Free!
could you explain?
Old 08-19-2002, 05:34 PM
2lowintegra's Avatar
someone said every 1000 miles........that's a little overkill......
Old 08-19-2002, 06:06 PM
1GreyTeg's Avatar
Roughly every month or definately at every AutoX event.
A.
Old 08-19-2002, 06:31 PM
Willard's Avatar
once a month
Old 08-19-2002, 06:49 PM
py1188's Avatar
Default Re: how often do you rotate your tires? (Willard)
Once a month.....hard driving
every oil change......easy driving
Old 08-19-2002, 06:51 PM
kkim's Avatar
Default Re: how often do you rotate your tires? (toolowintegra)
if you're refering to me, my tires last me 6-8k miles/set. every 1-2k miles is roughly 1/6 to 1/4 the life of the tires. my rotation schedule is the same for the percentage of the life of the tires if yours last you 20-30k and you rotate every 5k miles.
overkill? I think not... any longer and the tires start to have weird wear patterns and I end up buying tires sooner than expected.
Old 08-19-2002, 08:09 PM
nsxtcjr's Avatar
Default Re: how often do you rotate your tires? (kkim)
I swap my tires for the track tires at track events (~6 times a year), so whenever I put the street tires back on, I always put the ones with more tread on the front. Same thing in spring when I swap back from winter tires.
Old 08-19-2002, 08:12 PM
nEoMuGen's Avatar
Default Re: how often do you rotate your tires? (nsxtcjr)
Every Autox/track...I inspect both my street and track tires and rotate if necessary.
I tend to be lazy during the winter.
Old 08-19-2002, 10:13 PM
mr poo's Avatar
Go to Costco, Free!
could you explain?
hehe, if you buy tires from them, you get a great coverage plan. free roadside hazard warranty, free patch up when u get a nail, and free rotation for as long as the tire lasts. other stuff too but i dunno kno all of it, my parents get their tires there
Old 08-19-2002, 10:25 PM
C Squared's Avatar
Default Re: how often do you rotate your tires? (mr poo)
when i change my oil
Old 08-19-2002, 10:32 PM
Mr. Choi's Avatar
once a year if im lazy, twice a year if im bored. ususally every
15000 - 25000 miles.
Old 08-19-2002, 10:53 PM
Art Vandeleigh's Avatar
Default Re: how often do you rotate your tires? (Chois i-VTEC)
off season about 7k one season almost after every event.
Bjorn20
04-24-2008 01:37 PM
hondajustin
04-21-2008 02:35 PM
UA6 BALLER STATUS
04-20-2005 09:38 PM
MeanGreenEG9
04-13-2003 09:10 PM
Quick Reply: how often do you rotate your tires?
