how can you tell when your motor mounts are bad?
Old 05-26-2009, 07:16 AM
hondaon18's's Avatar
Default how can you tell when your motor mounts are bad?
i got a hatch with a b16 in it but i want to know is how or what noises do you hear so you can tell when your motor mounts go bad. i would like to know? i know beside movement what noises can it make to determine if its bad.
Old 05-26-2009, 07:50 AM
1LowSol's Avatar
Default Re: how can you tell when your motor mounts are bad?
Should just be able to visually inspect them and determine. For example on mine, My Driver side lower motor mount was Blown out... I got under the car and looked and there was no rubber left inside the motor mount.
Old 05-26-2009, 08:19 AM
goldfinger93030's Avatar
you should feel vibrations like crazy if they have gone bad
Old 05-26-2009, 08:25 AM
stagen's Avatar
Or if they'r like mine the motor will hit the hood on hard shifts :/ New mounts are on their way tho.
But usually you can visually inspect them for cracks or missing rubber. Or if you've rcently develposed some really bad wheel hop. Also a problem of mine now.
Old 05-26-2009, 08:28 AM
I'm not Rick!
rick_rabies's Avatar
your motor will fall out....it happens
Old 05-26-2009, 09:07 AM
thurmondauto's Avatar
There are two ways a motor mount can really go bad,
1. Crack in the rubber
2. Damaged bolts ( *RARE* only happens to race cars, unless your pushing 1200 hp +)
I recently broke a motor mount and I will post pictures up of what you should look for!
Old 05-26-2009, 09:18 AM
Thats a cracked motor mount I did not have the time to circle the crack but you should be able to see it.
Old 05-26-2009, 10:31 AM
ok so on my when i go over speed bumps i here like on my pass side like hard hits and bad noise. at first i thought that is was my rack making the noise but i replaced that and i also replaced all my suspension but all that i got left is the mounts. that is what i think could be making noise cause it makes like real loud clunks noises
Old 05-26-2009, 10:34 AM
Adankid's Avatar
its your transmission bracket.
Old 05-27-2009, 09:59 AM
the one that go's to the side of the trans or the top one are you sure. how else can you tell?
95accordian
02-02-2014 10:48 PM
civicsi18
10-27-2008 12:05 PM
manyakiexpi
05-17-2006 09:56 PM
Flamenco-T
11-29-2001 10:55 PM
Quick Reply: how can you tell when your motor mounts are bad?
