H22 in crx
#26
Re: H22 in crx
It sounds like you need to start considering some suspension set ups. I've been thinking about doing a H22A swap also. Have been trying to figure out a good spring rate combo that will not be so harsh on the street but can hold its own on the track.
What year/car is your H22A out of? Also, what mounts did you go with? Did you have any hood or oil pan clearance issues? I want to do the JDM H22A but not sure if I can BAR it here in California. It sounds like you just got your swap in, but are you going to BAR that beast?
#27
Re: H22 in crx
#28
#29
Re: H22 in crx
I have had an H2B crx and a regular h22 swapped ef hatch. I cant stress ground clearance enough to people who want to do this swap.. Especially if you are going to lower it! On esp's car, the pan was like 3" from the ground on a 2" drop.. That is not nearly enough.
And make sure the engine is mechanically sound before putting it in, because any big job, such as timing belt, clutch, headgasket, etc, the engine will need to come out =/. There is no room in the bay for major service work.
And you will need coilovers to adjust for the heavier drivers side. Both of my h22 swapped ef's were lower by an inch or two on the drivers side, without me in it! ( I weigh another 180-190lbs)
If you just have to have an h22, I would say H2B or bust. The price you pay for regular mounts makes it a no brainer imo. It will save you some headaches.. but certainly not all of them.
If you want to utilize your cable driven speedo, you can mate the top half of a Cable VSS from 86-89 accords (and possibly ludes?) to the bottom half of your H/F-series Electronic VSS. *Thanks 2point2* And Confirmed by Me!
#30
Re: H22 in crx
ive put my head and my timing belt on while it was in the car. its better than pulling the whole damn thing out if you ask me
#31
Re: H22 in crx
cant wait for you to get done well be in the process of this same swap. Just waiting on my harness to get done by chasebays its been like 16 weeks keep pushing the date back so pissed!!
#32
#33
Re: H22 in crx
sorry bout the no updates guys...anyways i just made a thread for my build.
https://honda-tech.com/forums/showth...1#post40203929
Shes almost done...time for the engine now! will drive her for about a week or two then time to store again and start on the engine swap!
thanks for all the info on the swap!
EnSAn
15
08-05-2006 11:25 PM
racerose
07-27-2006 03:17 PM
