> Tech/Misc
Old 04-28-2009, 06:55 AM   #1
Atomic1
Default P0420 code question
B16 here
Can a leak at the joint between the A pipe and catalytic converter cause a P0420 code "Cat efficiency"?
My primary O2 sensor is mounted on the A pipe, and the secondary on the cat converter bung.
Atomic1 is offline   Reply With Quote
Old 04-28-2009, 08:53 AM   #2
ekb16
ekb16's Avatar
iTrader Rating: (1)
Send a message via AIM to ekb16
Default Re: P0420 code question
i believe its ur converter that is bad
B.A.R. member as of 3/18/09 JDM gsr in 98 hatch
Voches: chickwithastick,93allmotorcoupe,jomama,punoy69,Tom theman70
ekb16 is offline   Reply With Quote
Old 04-28-2009, 10:15 AM   #3
dtapia
2000 Honda Civic
dtapia's Avatar
Send a message via AIM to dtapia
could be a bad cat depends where the primary o2 was installed. how far in front of the cat ?
and if its on the flange area then most likely a bad cat.
the leak between the a pipe and the cat could cause a issue but depends on the leak how bad is the leak?
MASTER ACURA TECH and HONDA TECH
26 years with HONDA/ACURA
dtapia is offline   Reply With Quote
Old 04-28-2009, 04:32 PM   #4
Atomic1
Stock setup. The primary O2 sensor is mounted on the stock A pipe.....so about 6" from the joint. The secondary sensor is on the outlet end of the stock cat.
Can a leak between the primary O2 sensor and the cat cause a catalyst inefficiency problem?
I understand that this code means my secondary sensor output isn't flat enough, but what I'm asking is if a leak where I described will cause the catalyst to underperform.
Old 04-28-2009, 09:14 PM   #5
dtapia
2000 Honda Civic
dtapia's Avatar
could cause a exhaust dilution during a smog test but it would have to be open to create a condition like that.
Old 04-29-2009, 05:57 AM   #6
Atomic1
Interesting, I have another Master Honda Tech telling me this:
Running rich will decrease catalyst efficiency.
Running lean will decrease catalyst efficiency.
Exhaust leak before the cat will decrease catalyst efficiency.
I'll have to find out why....
Old 04-29-2009, 07:07 AM   #7
92_civic
po420 code sets when switching time between front and rear 02's is out of range...it does not automatically mean the cat is bad
an overly rich condition will cause the code because of the excess fuel in the exhaust stream causing the rear 02 to "think" the cat is bad because it did not see enough of a change from the front 02 reading
an overly lean condition will cause the code for the same reasons
also both of these conditions can cause the catalyst to operate outside of it's intended temperature range...the same thing that an exhaust leak ahead of the rear 02 will cause to happen
I've seen people throw cats in a car for a po420 code that really only needed a tune up...brand new cat installed, cel cleared, and a week later the code is back on the the po420 and throwing a new set of plugs in it keeps the light out...
so...check your tune up stuff, and fix your exhaust leak and your po420 code will probably go away...hope that helps
92_civic is offline   Reply With Quote
Old 04-29-2009, 10:21 AM   #8
Atomic1
Exactly why I'm asking before following the knee jerk reaction everyone seems to have with the P0420 and replacing the $800 stock cat.
Will try to narrow the problem down. thanks
Old 04-29-2009, 10:25 AM   #9
dtapia
2000 Honda Civic
dtapia's Avatar
let us know what you find then.
Old 04-29-2009, 10:28 AM   #10
dtapia
2000 Honda Civic
dtapia's Avatar
here is some more food for thought
Before Checking a Catalytic
Converter DTC
Before you troubleshoot an OBD II vehicle that stores
DTC P0420 (67) (catalyst system efficiency below
threshold), run these quick checks:
1. Check for a leak in the exhaust system. If you find
one, repair it, clear the DTC, and test-drive the
vehicle.
• If the DTC doesn’t come back, return the vehicle
to the customer.
• If the DTC returns, go to step 2.
2. Connect the PGM Tester, and test-drive the vehicle
while an assistant monitors the voltage signal from
the secondary oxygen sensor (HO2S S2). After the
catalyst reaches operating temperature, the HO2S S2
voltage should stay between 0.5 and 0.8 V at steady
cruising speed. During deceleration, the voltage
should be steady at 0.1 V or less.
• If the voltage readings are OK, clear the DTC, and
return the vehicle to the customer.
• At cruising speed, if the voltage fluctuates or stays
below 5 V, go to step 3.
3. Measure the inlet and outlet external temperatures of
the catalytic converter with a thermometer capable
of reading up to 500°F.
• If the outlet temperature is more than 100°F hotter
than the inlet temperature, the converter is OK;
clear the DTC, and return the vehicle to the
customer.
• If the outlet temperature is less than 100°F hotter
than the inlet temperature, replace the converter.
Old 04-29-2009, 12:10 PM   #11
92_civic
bingo! the temp test and 02 voltages test was the part I left out on my first post, I was just coming back to add to it, but you beat me to dtapia
http://www.ondemandperformance.com
your RI source for performance
IN HOUSE CHASSIS DYNO http://images.honda-tech.com/set1/smile/emthup.gif
WTB: 4g63 WIDEBLOCK or 4g64 RWD
Old 04-29-2009, 12:36 PM   #12
dtapia
2000 Honda Civic
dtapia's Avatar
So what are the results
Old 04-29-2009, 12:56 PM   #13
Atomic1
I wont be able to get under the car until next week. Once I get back to my normal garage I'll fix the gasket leak and let you guys know the results.
Old 04-29-2009, 07:51 PM   #14
dtapia
2000 Honda Civic
dtapia's Avatar
we will be here.
Old 04-30-2009, 07:08 PM   #15
KWayRacing
KWayRacing's Avatar
I am very interested in the results bumpdy bump
KWayRacing is offline   Reply With Quote
Old 04-30-2009, 07:17 PM   #16
www.megameet.org
www.megameet.org's Avatar
if the cat is bad you can always add in a o2 extender on the secondary o2, and then you wont need a cat $5 fix
|O\==H==/O|
www.MegaMeet.org
Head of Operations, Logistics and Security
www.megameet.org is offline   Reply With Quote
Old 04-04-2010, 01:08 PM   #17
Atomic1
Old 04-04-2010, 04:06 PM   #18
Scott_Tucker
Scott_Tucker's Avatar
Send a message via ICQ to Scott_Tucker Send a message via AIM to Scott_Tucker
Originally Posted by Atomic1 View Post
B16 here
Yes, it could.
Coming April 2013, DeAnza College, Cupertino Ca.
Auto 64HP - High Performance Engine Preparation
Taught by Scott Tucker
Scott_Tucker is offline   Reply With Quote
2000, acura, catlytic, civic, codes, converter, exhaust, heat, honda, leak, p0420, po420, rsx, sensor, tech, troubleshooting
