Engine Rotation Direction Question
Old 04-27-2009, 08:54 AM
bubba_crx's Avatar
Default Engine Rotation Direction Question
I was wondering what direction a b series (specifically a B17) engine rotated. And what direction a 4AG (specifically a 4-AGZE) rotates. Any info would be very helpful.
bubba_crx is offline
Old 04-27-2009, 09:13 AM
jdm602's Avatar
Default Re: Engine Rotation Direction Question
ccw on the pulley side.
jdm602 is offline
Old 04-27-2009, 09:42 AM
bubba_crx's Avatar
What about where it goes into the trans... basically I need to know if a b series spins the same way into the trans as a 4ag
Old 04-27-2009, 09:54 AM
PatrickGSR94's Avatar
No, it does not. Most all engines in cars spin clockwise when viewing the front of the engine (pulley/accessory end), and counter-clockwise when viewing the rear of the engine (transmission end).
Pre-2000 Honda engines are one of the oddballs in the engine world, spinning CCW when looking at the front, CW when looking at the rear. Since 2000, the K-series engine started going into several Honda models, which rotates clockwise like most engines.
So the answer is, B-series engines rotate the opposite direction from 4AG (and all other) Toyota engines and transmissions.
PatrickGSR94 is offline
Old 04-27-2009, 01:08 PM
bubba_crx's Avatar
Thanks for the info... so I take it there is no way to make the b series on a yota trans work.. What honda motors spin clockwise?
Old 04-27-2009, 01:28 PM
Transpoquick's Avatar
pretty sure the k series spins cw.
Transpoquick is offline
Old 05-03-2013, 11:18 PM
Dalon honda's Avatar
there is a way and i want to figure it out, it has nothing to do with fuel or the motor just timing and starter/adaptor plate. This is not the first time I have seen a b series spin the other direction usually the only problem is finding a tranny to go backwards
Dalon honda is offline
Old 05-03-2013, 11:20 PM
f20 from the s2000 and the j series and the c series spin clock wise
Old 05-05-2013, 11:00 PM
Badweather Jim's Avatar
Is there any harm in rotating the crank the wrong direction?
Badweather Jim is offline
Old 05-06-2013, 01:30 PM
The crank by itself? Probably not. But if everything is hooked up then you risk problems like timing jumping teeth on the timing belt, and possible piston/valve interference. The T-belt tensioner pulley will not operate properly if the engine is rotated backwards.
Crew Chief
05-02-2020 03:37 PM
tmurrr56
03-18-2013 04:23 AM
CARMA_626
11-07-2010 07:55 AM
Quick Reply: Engine Rotation Direction Question
