05 RSX-type s: Cylinder 4 misfire... diagnostics?
Old 04-12-2009, 10:07 AM
DarkBB4's Avatar
Default 05 RSX-type s: Cylinder 4 misfire... diagnostics?
Hey, i just bought a 05 RSX-type s w/ 62K on it. the CEL for cylinder 4 misfire came on the other day, and turns on and off every once in a while... I just changed the spark plugs, and there was slight "rust" residue on some of the coil packs... The CEL hasn't came on since i did the plugs.
How can i diagnose the problem further?
Old 04-12-2009, 02:37 PM
DC5/EP3 MOD :)
Type-Spaz's Avatar
Default Re: 05 RSX-type s: Cylinder 4 misfire... diagnostics?
if it specifically cyl #4 swap your coil with another cyl and see if the problem changes cylinders also
Old 07-03-2014, 04:18 AM
ONEMISSEDSI's Avatar
I HAVE THIS SAME ISSUE.... ONLY ON NUMBER 4, AND IVE SWAPPED COILS AND IT CAME BACK ON AFTER 826 MILES AFTER THE FACT
Old 07-03-2014, 07:32 AM
mustclime's Avatar
check valve lash , clean your grounds.
Old 07-30-2014, 11:44 AM
SquidByrd's Avatar
I have a friend who has this issue before and his was due to 1 of the injectors not firing properly. Not sure how true this is being that he told me word of mouth and I didn't actually get to see if for myself...
Noel Yeow
Honda Civic (2001 - 2005)
07-26-2012 10:16 PM
Blown383
03-12-2008 10:20 PM
LFA Squad :: iTO
06-06-2006 02:43 PM
crum
10-09-2005 05:29 PM
Quick Reply: 05 RSX-type s: Cylinder 4 misfire... diagnostics?
