Part number of door lock rod holder plastic bracket?
Old 05-23-2022, 04:29 PM
k3ntegra's Avatar
Default Part number of door lock rod holder plastic bracket?
I made the mistake of buying part no. 07-06205-15461, and turn out not being the part, instead it was philips head screw anchor. Without this, I need to walk over the passenger side and lock the car with the adjacent door lock.
I've included an image, with the bottom most one, and image of what I'm looking for. Mine snapped in two. Car is an Integra coupe 3rd generation.
Imgur link is a full res image.
Code:
https://i.imgur.com/2IpuSwP.png
Old 05-23-2022, 11:14 PM
Premium Member
nd4sped's Avatar
Default Re: Part number of door lock rod holder plastic bracket?
Going to say if you can create a STL file I can 3D print what you are after.
Old 05-24-2022, 01:40 PM
k3ntegra's Avatar
Thank you for responding.
I found the part number is 72139-SR3-003, and with the help of Google images came across the following thread here on Honda-Tech.
Part is not available on Amazon nor eBay.
I've included STL and one SKP file of the model in the following links. Both links contain the same content.
https://drive.google.com/file/d/1Ju-...ew?usp=sharing
https://www.mediafire.com/file/u0ppu...odels.zip/file
3.5 to 3.6 mm is the approximate diameter of the door rod, I've also included a 2nd model of 4.0 diameter thru-hole, in case 3.6mm is too small. Either probably 4mm is probably the way to go.
Edit: I did a search for "door lock rod clip 6mm hole", on eBay, and came up with useful results.
accord96lx
05-02-2021 11:37 AM
Jayk00CivicEx
03-14-2012 08:17 PM
pakn-heat
03-01-2011 05:58 AM
Import_Fan
02-15-2007 04:19 AM
fourthchirpin
11-04-2004 07:47 PM
Quick Reply: Part number of door lock rod holder plastic bracket?
