EG driverside window hard to roll up and down
Old 01-14-2009, 01:20 PM
myflyintegra's Avatar
Default EG driverside window hard to roll up and down
My 95 EG dx has manual window and lock(dammit) but my driver side window is super hard to roll down after it gets bout half way, but sometimes it will be hard all the way down, and its hard to get up. Any suggestions off the top of ur head would be nice. Thanks. I have not popped off the panel to look inside or anything., Jus gettin ideas of what it could be.
Old 01-14-2009, 01:32 PM
stevieteg's Avatar
Default Re: EG driverside window hard to roll up and down
Mine does the same thing, just when it's real cold out though.
Old 01-14-2009, 01:43 PM
Former User's Avatar
Go to Walmart and buy a spray can of Silicone lubricant. Spray some of this lubricant into both rubber side channels where the window glass slides. No need to remove the door panel. Roll the windows up and down several times. You should immediately notice that the windows roll up and down with much less effort.
Old 01-14-2009, 01:44 PM
trustdestruction's Avatar
Damnit Ron I was just about to say that!
lol
Haven't seen you on here before
Old 01-14-2009, 01:57 PM
Hey Stuart. I guess the problem might also be a bad or misaligned regulator, but I think Silicone spray is the place to start.
Old 01-14-2009, 01:59 PM
yea, definitely the place to start
it's the easiest/cheapest possible solution, so start with it
Old 01-14-2009, 02:21 PM
Well thanks alot guys. Yall are much help. Yea i deff gonna try the silicone thing first. lol. It rolls up and down fine, jus hard, and yea its gets harder as it gets colder. But ima try that. Thanks for the advice guys
odie88
04-16-2011 09:22 AM
mattyfo0z
01-07-2011 09:46 PM
shyboi4u
10-29-2005 09:03 PM
kliq
09-18-2003 08:59 PM
Quick Reply: EG driverside window hard to roll up and down
