> Honda CRX / EF Civic (1988-1991)
Old 11-05-2008, 03:27 AM   #1
Hondaisok
1991 Honda Civic
Hondaisok's Avatar
Default Is it best to remove spark plugs when the engine is warm, hot or cold?
I have a 91 hatch std 1.5. I did a search on here, but couldn't find anything related to this. I've got one plug that turns hard when trying to take it out and I don't want to strip it. What engine temp is the best to remove it?
Hondaisok is offline   Reply With Quote
Old 11-05-2008, 06:16 AM   #2
sleepingciv
sleepingciv's Avatar
iTrader Rating: (2)
Send a message via AIM to sleepingciv Send a message via MSN to sleepingciv Send a message via Yahoo to sleepingciv
Default Re: Is it best to remove spark plugs when the engine is warm, hot or cold? (Hondaisok)
its best to do it when its cold.
in your case if its hard to get out cold try it warm and replace it warm
or if its hard to get out cold ... same as above lol
my vouch thread, but Google my screen name
http://www.hondamarketplace.com/show....php?t=3014109
sleepingciv is offline   Reply With Quote
Old 11-05-2008, 03:37 PM   #3
dacrxguy
dacrxguy's Avatar
Default Re: Is it best to remove spark plugs when the engine is warm, hot or cold? (honda.lioness)
Originally Posted by honda.lioness
From the manual:
"Avoid spark plug removal while the engine is hot. Since the cylinder head spark plug threads are aluminum, the spark plug becomes tight due to the different coefficients of heat expansion. If a plug is too tight to be removed even while the engine is cold, apply a solvent around the plug followed with an application of oil once the solvent has penetrated the threads. Do this only when the engine is cold."
The best "solvent" I have found is called PB Blaster. I highly recommend it. One can buy it at autozone, Wal-Mart, and the like for around $5 a can.
If you strip the threads, I am confident the archives here have a lot of advice.
nuff said theses aluminum heads are really delicate and the best way to fix a striped thread would be removal of the head there is also another proces were u taper the head w/out removal of the head
ps3 name= dacrxguy
dacrxguy is offline   Reply With Quote
Old 11-05-2008, 03:59 PM   #4
1990hondacrx
1990hondacrx's Avatar
Default Re: Is it best to remove spark plugs when the engine is warm, hot or cold? (dacrxguy)
the guy said he was worried about stripping he didn't say it was striped next time u take the plug out what i have found works really well so it doesn't squeak and act tough coming out apply a little dab of ANTI SEIZE on the threads it will withstand the heat and it will not allow the threads to be dry and hard to turn they will turn very free and work correctly i believe what your experiencing is just dry metal kinda like a squeaky door hinge
My Crx Build Thread:
http://www.honda-tech.com/showthread.php?t=2782503
1990hondacrx is offline   Reply With Quote
Old 11-05-2008, 04:33 PM   #5
jon4honda
jon4honda's Avatar
Default Re: Is it best to remove spark plugs when the engine is warm, hot or cold? (1990hondacrx)
definatly cold
1993 honda del sol JDM B16
1989 honda civic hatch D15
http://www.youtube.com/watch?v=btt-V...eature=related
jon4honda is offline   Reply With Quote
Old 11-05-2008, 04:39 PM   #6
accordaffair
accordaffair's Avatar
Send a message via ICQ to accordaffair Send a message via AIM to accordaffair
I don't believe pb blaster is a solvent, it's an oil
a solvent would be something like lacquer thinner
accordaffair is offline   Reply With Quote
Old 11-05-2008, 04:54 PM   #7
bharry07
bharry07's Avatar
Default Re: Is it best to remove spark plugs when the engine is warm, hot or cold? (accordaffair)
Do it while cold. This way you don't mess anything up while
torquing them back in.
96 Cabby 78 Rabbit
JDM=German.....almost http://images.honda-tech.com/set1/smile/embeer.gif
bharry07 is offline   Reply With Quote
Old 11-06-2008, 03:17 AM   #8
Hondaisok
1991 Honda Civic
Hondaisok's Avatar
Default Re: Is it best to remove spark plugs when the engine is warm, hot or cold? (jon4honda)
I actually did use antiseize when I installed them, but maybe I'm just a little paranoid about stripping them. I use PB Blaster all the time, so I'll try a little of that first and remove them cold.
I'm guessing its not a good idea to use my electric impact wrench to remove them?
Old 11-06-2008, 04:02 AM   #9
Go_Race_Your_Self
Two Piece
1993 Honda Del Sol
Go_Race_Your_Self's Avatar
NaSTeBoyiix
no. use your rachet and extension and the correct spark plug socket
I <3 my DelSol
'93 Si Del Sol- Stock B16A with basic bolt ons. 154hp/109tq 93 pump
Go_Race_Your_Self is offline   Reply With Quote
Old 11-06-2008, 04:06 AM   #10
EFstyle
EFstyle's Avatar
Default Re: (Go_Race_Your_Self)
so what about a comp. test? doest the motor need to be warm?
'98 CX Hatch
EFstyle is offline   Reply With Quote
Old 11-06-2008, 09:36 AM   #11
accordaffair
I'd agree, I don't see how solvent could help free tight bolts/spark plugs, but pb blaster would
Old 11-06-2008, 01:29 PM   #12
zrickety
1991 Honda CRX
zrickety's Avatar
iTrader Rating: (1)
zrickety zrickety
Send a message via AIM to zrickety
Default Re: (accordaffair)
only cold. i wouldn't even do it warm. a normal rachet works best, and always use a torque wrench putting them back in. set to spec. again COLD
playing with it warm at all is asking for trouble
91 Crx Si (B16 SiR)
http://crxcommunity.com/viewtopic.php?f=26&t=32702
zrickety is offline   Reply With Quote
96, aluminum, blaster, civic, cold, engines, hard, heads, honda, pb, plug, plugs, remove, spark, tight
