my H2B EF
my H2B EF
hey guys im geting close to finishing my h2b so i thought id post up what i got done so far.the rest should be done hopefully within a week or two.
mods
motor/fuel/tranny
jdm h22
98+ITR 4.7 transmission
QSD H2B kit
esp 1/2 in alt upper kit
ebay header "for now"
kaizenspeed balance shaft elminator kit
euro R crank pulley
custom spacer
rosko egr block off
remove IAB plate & made 4 runners
aem itr CAI
bpi flock stack
90-93 accord fuel rail
B&M regulator
H23 tensioner swap
440 RC injectors
ACT 8 pound flywheel
ACT extreme pressure plate with 6 puck sprung disc
B&R catch can
walbro 225
hondata-gasket
suspension/brakes/interior
Full-race traction bars
Prothane suspension master kit
Prothane suspension shifter kit
Prothane suspension trailing bushings
tokico illumina shocks
skunk2 drag launch kit
rota slips
DA master cyl.
DA front brakes
ef SI rear brakes
SIR Seats
99 SI civic cluster
heres a few pic of the valve cover i had made. once i got it back i noticed the spark holes werent fully alinged in the center. contacted the guy & said he would try his best to fix it he had alot of movement with it but if not he would buy me a new cover.so im keeping my fingers crossed for now id sure love to have the space.we took off 2.5 inches wit the oil cap off & will be filling threw the oil vent holes.
Modified by NABeastRR at 4:32 PM 11/2/2008
Modified by NABeastRR at 10:17 AM 11/5/2008
mods
motor/fuel/tranny
jdm h22
QSD H2B kit
euro R crank pulley
custom spacer
rosko egr block off
aem itr CAI
bpi flock stack
B&M regulator
H23 tensioner swap
440 RC injectors
B&R catch can
walbro 225
hondata-gasket
rota slips
DA master cyl.
DA front brakes
ef SI rear brakes
SIR Seats
99 SI civic cluster
Re: my H2B EF (NABeastRR)
i guess i should post a few of the motor when i first got her.had a upper header on it with a jasma stamp.got my ebay header in & there is deff. a diffrence
ebay outside was roughly 1.670 & the jdm header was roughly 1.770 inches.
Re: my H2B EF (88ED8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88ED8 »</TD></TR><TR><TD CLASS="quote">Nice!! extra thumbsup for the VC, I wanted to do that but I am too lazy...</TD></TR></TABLE>
thanks man i hope it ends up working out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIXTY »</TD></TR><TR><TD CLASS="quote">Looks good, what kind of car? What mounts are you using?</TD></TR></TABLE>
88 EF hatch ,Hasport mounts & shiftlinkage
Re: (NABeastRR)
got most of the timing cover modded for the crank pulley & alt belt. also put the esp bracket on with 88-91 civic alt.
sry for the poor pic. but all i have is a cell camra phone.
Re: (NABeastRR)
when you go to put the engine in the car. Could you take good pictures of how much you have to mod the frame rail for the crank pulley to clear and clearance for the alternator belt? Ive seen a couple pictures on here. But nothing in detail. A friend of mine had to take a chunk out of the framerail.
Re: (AllMtrRex)
I moved the pulley half inch over soo there shouldnt be much banging from what ive read but time will tell & yes ill do my best to take pics with what i got.
Good build and good luck with everything, i got my build in my sig ... lol i did the same thing with my timing belt cover, except its a lil different! well keep up the good work
Re: (JayWest)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1BADEGDC2 »</TD></TR><TR><TD CLASS="quote">Good build and good luck with everything, i got my build in my sig ... lol i did the same thing with my timing belt cover, except its a lil different! well keep up the good work</TD></TR></TABLE>
thanks ill have to check it out.
Re: (JayWest)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JayWest »</TD></TR><TR><TD CLASS="quote">nice
plan on keeping it all motor?
wheres belleview? </TD></TR></TABLE>
central fl. bout 1.5 hr north of orlando.
for now i do wanna get it runing dyno it have fun, then upgrade with some pro1s re dyno have a lil more fun then 100 shot direct port.
Just comin back to reply about the question you had, but with that spacer so the timing belt doesnt walk, it was fine for me, everything lined up perfect! i also read on the h2n thread of someone sayin that theres belt kept braking cause it wasnt perfectly aligned, maybe mine was the same way and i evened it with the lil spacer or maybe just got lucky!
Re: (NABeastRR)
well i havent really heard of anyone having problems with there belts walkin, but the guy who did my exhaust also helped me put the motor together and when he saw it he said he really didnt like that much and just for safe measure he was gonna put the b16 one, he did however have to cut a lil out the center and for the key, but nothing a dremel cant do!
Re: (1BADEGDC2)
yeah the tech thats helping me said the same thing & your right took a dremel to it ,but maybe the b16 one is diffrent.I never thought of it cuz it is made to go out there where the h22 i tried is only on the back side ya know.
Re: (NABeastRR)
yea, the h22 goes in the back, then the timing belt, then the b16 one, we only used a b16 cuz thats what he had layin around, im sure another h22 one would do the job ... goos luck
