B16A speedometer/speed sensor problem
Old 10-03-2008, 12:22 PM
Richyrich1988's Avatar
Default B16A speedometer/speed sensor problem
ok here it is. i have a 88 honda CRX with a JDM B16a with jackson racing supercharger and many other parts but my problem lies in my speedometer. the speedometer worked for about the first year i had it. i've had it for almost 3 years now. my RPM's work fine just speedometer. i have changed the speed sensor itself but that did not fix the problem so i think its in the wiring. also my gauge cluster is not the factory honda crx gauges. im not sure which they came from but redline is at 8 and top speed says 140. im pretty sure they go with the motor. my motor came out of a 91 crx i presume since its a true B16A not A1 or A2. from what i've heard they put B16A's in the 91 crx's. so when they did the motor swap they converted it from the classic speed cable to electric reading i guess cause the old cable is not in use. but i have spent hours on this and its beyond me any help will be greatly appreciated!!! thanks!!!! O and one more thing i forgot to mention. i have an aftermarket Zdyne ECU and my check engine light is on probably because the Speedo dosen't work but for some reason my VTEC still works despite the Speedo not working lol so i dont know why the speedo dont work but at least i have VTEC. anyway i would like to try and get the speedo back up and running. any help will be greatly appreciated!!!!
The Motor:
And here is the Speed Sensor
Modified by Richyrich1988 at 3:00 PM 10/3/2008
Modified by Richyrich1988 at 3:19 PM 10/3/2008
Old 10-03-2008, 01:10 PM
Default Re: B16A speedometer/speed sensor problem (Richyrich1988)
it turns out the cluster that's in my car is an Integra GSR cluster. just to let yall know what im dealing with.
here are some pics of the car and cluster
Modified by Richyrich1988 at 2:37 PM 10/3/2008
Seats
Here is my Gauge Cluster
Modified by Richyrich1988 at 2:53 PM 10/3/2008
Modified by Richyrich1988 at 2:59 PM 10/3/2008
Modified by Richyrich1988 at 3:02 PM 10/3/2008
Beast2002
03-08-2011 11:29 AM
EF-8SiR
01-27-2009 08:34 PM
1kreationz401
02-22-2008 09:14 PM
b16a27
12-16-2004 08:52 PM
tegboi
10-17-2003 09:02 AM
Quick Reply: B16A speedometer/speed sensor problem
