30,000 mile maintenance
Old 09-18-2008, 01:48 PM
civic1234's Avatar
Default 30,000 mile maintenance
I'm comming up on 30k miles on my 07 sedan si. I was reading about how honda said the civics dont need any "tune-ups" untill 110k miles. well im in the process of getting new tires and thought what else is there to do... dont spark plugs, fuel filters, tranny fluids, stuff like need service from time to time? i can understand belts, water pump and other major stuff at 110k. just not everything else on the car..... ive looked around and cant seem to find anything in the manual or on the honda owner link explaining any of this.... if anyone knows or finds it please direct me in the right direction.
Thanks
Old 09-18-2008, 03:23 PM
25RFG2's Avatar
Default Re: 30,000 mile maintenance (civic1234)
I think they give the car an oil change, clean and inspect the brakes, top off all fluids and tire rotation.
Old 09-18-2008, 03:26 PM
i-VTEC_DOHC's Avatar
30k ur supposed to do a drain and fill for your tranny fluid. oil change, inspect brakes, im gonna do a coolant flush at 30k. rotate tires, the terminals on the battery might need some cleaning, pretty much just check all your fluids
Old 09-18-2008, 04:02 PM
Blk06Si's Avatar
30k mile services at my job consists of: Oil and oil filter change, drain and refill trans., brake fluid flush, set tire pressure with rotation of tires (used to have to balance also), change air filter and cabin filter.
Old 09-18-2008, 07:34 PM
93civicjaydm's Avatar
Default Re: 30,000 mile maintenance (Blk06Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blk06Si &raquo;</TD></TR><TR><TD CLASS="quote">30k mile services at my job consists of: Oil and oil filter change, drain and refill trans., brake fluid flush, set tire pressure with rotation of tires (used to have to balance also), change air filter and cabin filter.</TD></TR></TABLE>
Bingo!
Old 09-19-2008, 08:15 AM
civic1234's Avatar
Default Re: 30,000 mile maintenance (93civicjaydm)
when do you change the spark plugs and fuel filter?
Old 09-19-2008, 12:01 PM
CerealKiller's Avatar
I'll be doing these in a couple of weeks.
Old 09-21-2008, 01:52 AM
xplicit503's Avatar
Pretty much a routine check up except they want to actually dig into the car unlike their express service.
Best way to find out about it is to call the dealership/service center and ask.
Old 09-21-2008, 09:55 AM
kine462's Avatar
Default Re: (xplicit503)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic1234 &raquo;</TD></TR><TR><TD CLASS="quote">when do you change the spark plugs and fuel filter?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blk06Si &raquo;</TD></TR><TR><TD CLASS="quote">30k mile services at my job consists of: Oil and oil filter change, drain and refill trans., brake fluid flush, set tire pressure with rotation of tires (used to have to balance also), change air filter and cabin filter.</TD></TR></TABLE>plugs are 100k I don't recall ever changing a fuel filter unless I had to.
I doubt any dealer is going to flush your master cyinder....
As for a 30k service. The dealer I work for sells it as: LOF, tranny fluid change, coolant change, tire rotation, front and rear maintenence (inspect rotors/drums,pads/shoes, clean and lubricate slides,molycoat pads/shoes with a antiseize high temp lube mixture, and adjust rear shoes where applicable), and also we lube your window tracks, hood/door latches, and silicone your weatherstriping,and change your air filter
Modified by kine462 at 7:00 PM 9/21/2008
Old 09-21-2008, 02:14 PM
Blk06Si's Avatar
Default Re: (kine462)
We don't completely flush out the brake fluid out the resevoir. We take some out and keep adding until its cleaner. Used to bleed the brakes at each caliper but now they conserve brake fluid cause we used a lot when we bled each caliper. I prefer doing it just by the resevoir.
Old 09-21-2008, 05:07 PM
Hyaboosta's Avatar
Default Re: (Blk06Si)
A 30k at my honda dealer is new air filter,cabin filter, oil change,trans drain and fill, coolant drain and fill, rotate and balance tires and clean and adjust brakes.
All easy things
Old 10-17-2008, 03:51 PM
19slocivic97's Avatar
your car has maint. minder system, it will generaly call for a b12 service around the 25-30k mark, which is basic check over, air filter and cabin filter and oil change. trans fluid usually doesnt come up till 60k mark, and coolant is gonna be around the 100k mark when too you will cahnge the plugs and adjust the valves. Honda designed the mant. minder system === follow it
Old 10-21-2008, 05:06 AM
hrdsktr1988's Avatar
hey kine452 how much does it all run to get the whole 30k maint.
Old 10-21-2008, 09:26 AM
joeyjojoe01's Avatar
Default Re: (hrdsktr1988)
Here is the breakdown of the 30K service at my local dealership. Can anyone comment on what is reasonable and what isn't?
http://www.brilliancehonda.com...Menus
Old 03-10-2011, 07:53 AM
ccuman's Avatar
As for the cabin filter, the BIG,BIG box store sells a FRAM filter for approx. $20.00 and inside the filter box is all the instructions "location" to change the filter. Takes less than 10 mins. & my dealer wanted more than $75.00!!
Old 03-13-2011, 06:44 AM
Zebra's Avatar
I had a brake fluid change at the dealer (30K maintainance) and when I checked after the job, the master cylinder was very low on fluid. I think they just siphon the master cylinder dry and put new fluid in - at $75 a pop! (Less than $5 worth of fluid). I was under the false assumption that they opened the bleeders at the brake cylinders and totally flushed it - that is the way it should be done. Needless to say, I won't fall for that sucker deal again.
Old 03-19-2011, 07:04 AM
sjnardozzi's Avatar
I have an 06 Civic with 93,000 miles. Dealer says to flush the power steering fluid for over $100. Everywhere else I try to read says NEVER change power steering fluid unless it is contaminated. ALSO, does the 06 Civic need a valve adjustment or do they self adjust? Thanks. Any good independent service personnel in Westchester County, NY?
Old 03-19-2011, 12:44 PM
av911's Avatar
You can change the PS fluid whenever you want. DO NOT let them charge you $100 to do it. Here's a couple of DIYs:
http://www.8 thcivic.com/forums/suspension/202421-diy-power-steering-flush-r18.html
http://www.8 thcivic.com/forums/do-yourself-articles/77838-info-changing-power-steering-fluid.html
And the valves do not self adjust.
Old 03-22-2011, 01:56 PM
dc-upstate-si's Avatar
im right around the 30,000 mile mark and im chomping at the bit to change my tranny fluid
Old 03-29-2011, 09:56 AM
Zebra's Avatar
Yea, do it yourself - a very easy job. I measure the volume I remove and replace with equal amounts. That prevents overfills, given the amount in the transmission was correct when you begin the process. Dealers charge alot for this simple procedure.
teggy2154
02-28-2008 02:52 PM
ruracer18
Honda S2000
19
06-10-2007 07:31 AM
2qwik2nv
Acura TL, RL & ZDX
01-12-2003 02:25 AM
acatak
07-16-2002 06:18 AM
Quick Reply: 30,000 mile maintenance
