2003 accord v6 tcs and emergency brake light problem
Old 09-09-2008, 02:30 PM
markvangsta's Avatar
Default 2003 accord v6 tcs and emergency brake light problem
My car drives fine and i heard it was a common problem with this year. My tcs and emergency brakelight on the dash stays on when i drive. why is this? and how can i fix this? anyone knows please help me! THANKS!
Old 09-11-2008, 08:22 PM
phootbag's Avatar
Default Re: 2003 accord v6 tcs and emergency brake light problem (markvangsta)
Chances are the brake fluid level switch inside the resevoir has stuck. I have replaced a few master cylinders for this, ( the resevoir is NOT sold seperately ). If you unplug the brake fluid level connector, see if the BRAKE light goes out. If it does, you have found the problem. I'm sure the TCS DTC is related to this.
Old 02-21-2011, 05:54 PM
David Evers's Avatar
Have you had any succes in cleaning the resevoir with brake cleaner and putting new fluid back in.
neo702
07-26-2006 01:09 PM
kcb203
03-08-2006 11:27 AM
low430
10-30-2005 01:02 AM
teamguerino
09-04-2005 09:38 AM
ITR184
12-03-2003 05:40 AM
Quick Reply: 2003 accord v6 tcs and emergency brake light problem
