02 Civic EX D17 Overheating Please Advise
Old 06-12-2008, 11:33 PM
docksidedad's Avatar
Default 02 Civic EX D17 Overheating Please Advise
Just drove 815 miles, while on the highway at 75 MPH no troubles. When at lights idling, car overheats.
- No fluid loss
-Upper and lower hoses hot and presurized
- With A/C on both fans are running
What next?
Old 06-13-2008, 04:48 AM
andyman97's Avatar
Default Re: 02 Civic EX D17 Overheating Please Advise (docksidedad)
Thermostat or water pump....
Try replacing the thermostat firt, it's cheap.
Old 06-13-2008, 06:43 AM
texasnick's Avatar
check your coolant for oil / oil for coolant
Head gaskets seem to be reoccuring problems in 01-05s.
Old 06-13-2008, 06:58 AM
andyman97's Avatar
If you aren't losing coolant, it isn't the headgasket.
Old 06-13-2008, 07:23 AM
texasnick's Avatar
Default Re: (andyman97)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by andyman97 &raquo;</TD></TR><TR><TD CLASS="quote">If you aren't losing coolant, it isn't the headgasket.</TD></TR></TABLE>
oops....I didn't see that.
reading &gt; me
my bad.
Old 06-13-2008, 09:16 AM
Hey all,
I checked it this morning and I have combustion gases bubbing out of the radiator. Going to replace the head gasket. While I'm there I'm going to do the timing belt and water pump. Thanks for your replies.
Old 06-13-2008, 10:24 AM
matt701's Avatar
Just out of curiousity, how many miles does your car have? I have the 02 EX as well, wondering when to start worrying.
Old 06-13-2008, 10:30 AM
rushbuster70's Avatar
mine did it around 70k
Old 06-13-2008, 10:34 AM
Curiouz_G's Avatar
you cant just expect issues like that with just mileage. you have to consider the condition/wear of the motor during that mileage
Old 06-13-2008, 10:55 AM
andyman97's Avatar
Combustion gases in the radiator? How exactly are combustions gases getting into the radiator?
Sounds like it could be as simple as a radiator cap not keeping the system pressurized. You're giving way too little and way too vague info to diagnose it.
Old 06-13-2008, 09:01 PM
Tha car has 68K on it.
As far as the vague info, the combustion gases from one or more of the cylinders is higher than the pressure in the coolant system. Thus when the head gasket is leaking between the coolant passage and the cylinder, the combustion gases enter the coolant system system.
I am going to have a machine shop shave the head to ensure its not warped at all. There are tolernces in the service manual for that specification.
I've never had any engine do this so early. I under this happens with the hondas occasionally.
5kyhawk
08-18-2016 06:47 AM
som3on3_10
05-18-2006 06:56 AM
kysard
21
08-31-2004 04:33 PM
redsled00
01-22-2003 07:40 AM
Quick Reply: 02 Civic EX D17 Overheating Please Advise
