Fuel Pump Relay Location???
Old 04-30-2008, 09:55 AM
TurboKneeGrow's Avatar
Default Fuel Pump Relay Location???
Where is the fuel pump relay located on a 98 Honda Civic? Thanks for your help. I'm thinking thats what my problem is. My fuel pump isn't turning on. I checked the fuse (its good) and I took the pump cover off and all the wires are still connected. I want to check the relay before I buy a new fuel pump.
Old 04-30-2008, 10:42 AM
gibsanez's Avatar
Default Re: Fuel Pump Relay Location??? (TurboKneeGrow)
Should be under the dash on the driver side, kinda burried.
Old 04-30-2008, 12:43 PM
Default Re: Fuel Pump Relay Location??? (gibsanez)
is it labeled? i see a white one bolted to the body in front of the hood release and next to the fuse box. part # is 38380 S04 A020 M1
Modified by TurboKneeGrow at 4:54 PM 4/30/2008
Old 04-30-2008, 01:18 PM
bump.
Old 04-30-2008, 01:19 PM
jdmeg6118's Avatar
No not on driver side....take out your glovebox and look to the right it's sitting up there with a 10mm behind it it's a grey box with a bunch of wire's going to it it unpug's...
Old 04-30-2008, 01:23 PM
tambara's Avatar
Default Re: Fuel Pump Relay Location??? (jdmeg6118)
my relay was under the driver sides dash. I guess every honda is different.
Old 04-30-2008, 01:26 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmeg6118 &raquo;</TD></TR><TR><TD CLASS="quote">No not on driver side....take out your glovebox and look to the right it's sitting up there with a 10mm behind it it's a grey box with a bunch of wire's going to it it unpug's... </TD></TR></TABLE>
Ok, cool. thank you.
Old 04-30-2008, 01:35 PM
Does this one look right? I took it from behind the glove box, bolted to the right side of the dash.
Sorry for the shitty cell phone shots.
Old 04-30-2008, 01:38 PM
jdmeg6118's Avatar
Yes sir you found it!
Old 04-30-2008, 05:04 PM
good haha. now to get another and see if thats what the problem was.
snzh22
08-08-2007 04:53 PM
bb4socal
02-11-2006 06:22 PM
YodajdmEK4
10-03-2005 09:24 AM
wickedEFguy
08-04-2004 08:23 AM
b16acrxer
11-13-2003 07:21 PM
Quick Reply: Fuel Pump Relay Location???
