Car won't start on first try - takes a few tries
Old 04-07-2008, 05:44 PM
b18cEK's Avatar
Default Car won't start on first try - takes a few tries
Hi, I just bought a new car and it takes a few times of turning the key before it actually starts. It doesn't even crank until I turn the key for the 4th time or so and then it actually starts up on the first time it cranks.
Could it be the ignition switch, low fuel pressure?
Everything is stock on this '99 SI.
Any input is appreciated.
Thanks!
Modified by b18cEK at 11:53 PM 4/7/2008
b18cEK is offline
Old 04-07-2008, 05:49 PM
DCSportEJ1Civic's Avatar
Default Re: Car won't start on first try - takes a few tries (b18cEK)
if it doesnt crank its something with your starter or ignition switch. i would guess a bad starter or a bad connection somewhere.
DCSportEJ1Civic is offline
mechanix619's Avatar
It could be so many things. Can you get the accessories to work? Check the alt, battery, starter, and ignition.
mechanix619 is offline
Old 04-07-2008, 05:51 PM
Blzdeep's Avatar
Default Re: Car won't start on first try - takes a few tries (DCSportEJ1Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DCSportEJ1Civic &raquo;</TD></TR><TR><TD CLASS="quote">if it doesnt crank its something with your starter or ignition switch. i would guess a bad starter or a bad connection somewhere.</TD></TR></TABLE>
ya, i'd start here before you tear into everything else it "could" be.
Blzdeep is offline
Old 04-07-2008, 06:02 PM
b18cEK's Avatar
Default Re: Car won't start on first try - takes a few tries (Blzdeep)
What about main relay???
b18cEK is offline
Old 04-07-2008, 06:04 PM
b18cEK's Avatar
Default Re: Car won't start on first try - takes a few tries (mechanix619)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mechanix619 &raquo;</TD></TR><TR><TD CLASS="quote">It could be so many things. Can you get the accessories to work? Check the alt, battery, starter, and ignition.</TD></TR></TABLE>
Accessories work. Definitely not the battery.
I was thinking ignition switch or main relay?
b18cEK is offline
Old 04-07-2008, 06:36 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18cEK &raquo;</TD></TR><TR><TD CLASS="quote">
When you turn the key to ACC can you hear the Main Relay click, can you hear the fuel pump prime? If no to either then it's Main Relay or fuel pump.
Old 04-07-2008, 07:33 PM
Mugen112's Avatar
Does it not crank at all until the 4rth try? Sounds like an ignition problem. A main relay would still allow it to crank. It may be a dead spot in the starter as well, but it would only do this sometimes (not all the time). GL.
Mugen112 is offline
Old 04-07-2008, 07:43 PM
b18cEK's Avatar
Default Re: (Mugen112)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugen112 &raquo;</TD></TR><TR><TD CLASS="quote">Does it not crank at all until the 4rth try? Sounds like an ignition problem. A main relay would still allow it to crank. It may be a dead spot in the starter as well, but it would only do this sometimes (not all the time). GL.</TD></TR></TABLE>
it depends... sometimes it's the second time and sometimes it could be the 7th time...
ignition switch?
b18cEK is offline
Old 04-07-2008, 07:44 PM
jasonjdm's Avatar
let your fuel pump prime
jasonjdm is offline
jasonjdm's Avatar
or check grounds and main relay
jasonjdm is offline
Old 04-07-2008, 07:47 PM
b18cEK's Avatar
Default Re: Car won't start on first try - takes a few tries (jasonjdm)
I hear the fuel pump click everytime, so I do not think it's the main relay or fuel pump...
b18cEK is offline
Old 04-07-2008, 07:51 PM
NoBrows's Avatar
can you hear the starter turning? if you can check the coil ive seen this problem many times
NoBrows is offline
Old 04-07-2008, 07:53 PM
b18cEK's Avatar
Default Re: (NoBrows)
you cannot hear the starter turning
b18cEK is offline
Old 04-07-2008, 07:58 PM
NoBrows's Avatar
Default Re: (b18cEK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18cEK &raquo;</TD></TR><TR><TD CLASS="quote">you cannot hear the starter turning</TD></TR></TABLE>
then sounds like you have a bad starter next time it doesnt crank hit it with a hammer and see if it dont crank right up
NoBrows is offline
Old 04-07-2008, 08:08 PM
b18cEK's Avatar
the starter doesn't make any noise at all though? the starter doesnt even click?
but then on maybe the 4th attempt to start it it cranks over fine and starts up!
b18cEK is offline
Old 04-07-2008, 08:09 PM
NoBrows's Avatar
yeah i bet the starter contacts are all f'ed up
NoBrows is offline
Old 04-07-2008, 08:11 PM
b18cEK's Avatar
what do you mean by the contacts being messed up? corroded? or just not connected properly? Would that mean i need a new starter?
b18cEK is offline
Old 04-07-2008, 08:22 PM
NoBrows's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18cEK &raquo;</TD></TR><TR><TD CLASS="quote">what do you mean by the contacts being messed up? corroded? or just not connected properly? Would that mean i need a new starter?</TD></TR></TABLE>
starter contacts lose their conductivity and stick , starters go bad so just go by a new one that should fix your problem try the hammer thing that will help you confirm the problem
NoBrows is offline
Old 04-07-2008, 10:27 PM
Mugen112's Avatar
Could be a bad starter (dead spot) or your ignition switch is bad.
Mugen112 is offline
Old 04-09-2014, 06:48 PM
asm383's Avatar
anybody resolve this problem im having the same thing and ive replaced new starter alternator battery cleans all leads terminals but if I jump it start up right away
asm383 is offline
Old 04-09-2014, 07:14 PM
Former User's Avatar
Ancient thread closed. Please create your own thread.
Former User is offline
rdzona
08-28-2014 10:13 PM
mongo592
Acura TL, RL & ZDX
11-09-2007 06:10 AM
reelhybrid
02-01-2007 03:05 PM
sohctodohc
10-18-2006 09:08 PM
turboxsi
01-29-2004 01:33 PM
Quick Reply: Car won't start on first try - takes a few tries
