Name this turbo
Old 04-04-2008, 12:09 PM
fastazzf22's Avatar
Default Name this turbo
Ok, I came across this turbo and I really dont know what series? t3t4, t4, t04e. The guy selling it knows nothing about it other than it being brand new and wants 300 for it. Here are some pics of it
Specs I got
Turbine- M-24 Garrett a/r.60
Compressor - garrett ar.69 m1 g1
Serial numbers - SP0480-04-M-5872
2004 JUN15 08179
409040-9011 5Z018
My turbine on my T3t4 turbonetics .57 trim is bigger, alot bigger than this one, I am talking about the blades.
Why would the nut on the exhaust side be grounded down like that ?
Any help would really be awesome, another thing is would you pay 300 for it.
Old 04-04-2008, 12:14 PM
fastazzf22's Avatar
Default Re: Name this turbo (fastazzf22)
oh yea , where can I find a exhaust flange for the downpipe? I cant even find this turbo on the internet anywhere??????
Old 04-04-2008, 12:33 PM
HybridKOOP's Avatar
I don't know what model it is, but the shaft nut is ground down for balancing of the rotating assembly.
Old 04-04-2008, 12:48 PM
fastazzf22's Avatar
Default Re: Name this turbo (HybridKOOP)
I figured that is what they did to the nut. Its an M-24 model garrett.
Even it is it a t3t4, a 60 trim would be bigger. Correct ?
Old 04-04-2008, 01:38 PM
Turbo-LS's Avatar
take the compressor cover off and measure the wheel with a micrometer or just with a ruler in MM. once you have wheel sizes you can somewhat figure it out. looks to be a T4 with on center turbine housing. m24 is an S cover compressor which in the case of this turbo is overkill because it lookes to have maybe a 50 trim comp wheel.
you could probably find out best by contacting garrett, but thats my best guestimation
IMO dont bother with this turbo. The price is right if it was a desirable turbo but for one you arent sure of specs and two a t4 turbine is overkill unless your trying to make big power and your not going to make much power on that compressor that you wold require a t4 turbine
Old 04-04-2008, 01:43 PM
extralargenog's Avatar
Its a T4.... not a hybrid. Look at the inlet flange.
Old 04-04-2008, 02:10 PM
fastazzf22's Avatar
Default Re: Name this turbo (Turbo-LS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo-LS &raquo;</TD></TR><TR><TD CLASS="quote">take the compressor cover off and measure the wheel with a micrometer or just with a ruler in MM. once you have wheel sizes you can somewhat figure it out. looks to be a T4 with on center turbine housing. m24 is an S cover compressor which in the case of this turbo is overkill because it lookes to have maybe a 50 trim comp wheel.
IMO dont bother with this turbo. The price is right if it was a desirable turbo but for one you arent sure of specs and two a t4 turbine is overkill unless your trying to make big power and your not going to make much power on that compressor that you wold require a t4 turbine</TD></TR></TABLE> Thanks for the info, I was noticing something else. My turbonetics t3t4 has a shorter bolt pattern on the compressor than the garrett. It wouldnt even bolt up to the manifold. Unless there is a flange to adapt the two. My hp goal is over 500. Thats why I was looking for something a lil bit bigger than the t3t4.
So a small wheel (turbine) and a big compressor isnt good ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by extralargenog &raquo;</TD></TR><TR><TD CLASS="quote">
Its a T4.... not a hybrid. Look at the inlet flange.</TD></TR></TABLE>
Please explain this one to me, the inlet flange is the same exact size as the t3t4, to be honest with ya, turbonetics is a 1/2 bigger inlet and the turbine is a hell of alot bigger.
Comparing the two, t3t4 first
now the garrett
Turbonetics just looks bigger to me. Especially the turbine.
Old 04-04-2008, 03:01 PM
ITS A STRAIGHT T4...
WRONG
.M-24 Garrett a/r.60... Thats the compressor, and alot of garret housings have that on them.
The turbine is on the hot side...
Its a straight T4 turbo.... both hot AND cold sides. You can tell (or at least I can) just by LOOKING at the turbine inlet flange.
You are welcome sir.
Old 04-04-2008, 03:14 PM
fastazzf22's Avatar
Default Re: Name this turbo (extralargenog)
learned something new today, the turbine is on the hot side huh. Damn all this long I thought it was the cold side.
Whats the hp capabilites? If the bolt pattern on the hot side is larger than the bolt pattern on the mani? Got any ideas on how to get it on there? What was is made to go on ? Still cant find a DP flange ????
All input is welcome/
Old 04-04-2008, 03:17 PM
Turbo-LS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastazzf22 &raquo;</TD></TR><TR><TD CLASS="quote">learned something new today, the turbine is on the hot side huh. Damn all this long I thought it was the cold side.
All input is welcome/ </TD></TR></TABLE>
You need to do ALOT of research if you are tryng to go for 500whp. Sorry dont mean to be rude but you got alot to learn my friend. Start asking alot of questions. For your goals a t/t4 60 trim with .69 or .82 turbine housing is plenty of turbo but your goiong to need to build the engine too.
Old 04-04-2008, 03:34 PM
fastazzf22's Avatar
No offense taken at all, always willing to learn.
SO this turbo supports the goal, now to get it mounted and a flange for the downpipe.
The bottom end is built, nothing in the head, I was told the b1 head will support 500 hp and shouldnt need internals unless I was spinning over 7200 rpm.
Old 04-04-2008, 03:43 PM
SpoolnG2's Avatar
M24 is actually just the casting material that the turbo is made out of. It has nothing to do with the model or size of the turbo.
Old 04-04-2008, 03:55 PM
1fastEK9's Avatar
Default Re: Name this turbo (SpoolnG2)
if I'm not mistaking tha turbo belongs 2 a diesel truck
Old 04-04-2008, 04:47 PM
fastazzf22's Avatar
Default Re: Name this turbo (1fastEK9)
Ok, so I bought the turbo, found all the flanges and I guess I will have a t4 on the accord soon.
Thanks for the advice and if you want to throw some more my way, Continue on .
Old 04-05-2008, 04:40 AM
Turbo-LS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastazzf22 &raquo;</TD></TR><TR><TD CLASS="quote">Ok, so I bought the turbo, found all the flanges and I guess I will have a t4 on the accord soon.
Thanks for the advice and if you want to throw some more my way, Continue on . </TD></TR></TABLE>
dude did you not read what peopel are saying. you should not have purchased that turbo man
Old 04-05-2008, 04:54 AM
fastazzf22's Avatar
Please tell me why I shouldnt have bought it. I went back and read all the post, and your the only one that says anything about not getting it. Then you say for my hp goals I need a turbo with For your goals a t/t4 60 trim with .69 or .82 turbine housing is plenty of turbo but your goiong to need to build the engine too. That is this turbo. Come on. I dont get why I shouldnt have gotten this, I need something to get me over 500hp. Will this turbo not produce that much power
Old 04-05-2008, 08:06 AM
zex_cool's Avatar
another bad move.
Xathine
12-30-2008 12:56 PM
zeroz
08-30-2005 10:22 PM
dominate9
06-06-2005 06:33 PM
1320DRAGWORKX
11-10-2004 08:50 AM
Turbo'dMex-A-Keen
06-10-2003 11:59 PM
Quick Reply: Name this turbo
