99 Honda Accord backlight problem
Old 04-01-2008, 11:48 AM
ferahgo's Avatar
Default 99 Honda Accord backlight problem
The car has no backlights around the gauges when driving. The thing that tells you if you are in 'D' or 'P' will light up, as well as the engine light and cruise. The headlights work, but when you turn them on everything goes completely black in the gauge cluster.
I have replaced the backlight bulbs even though they were not blown, and checked and replaced the backlight fuse even though it was not burnt, as well checked all the other fuses even the ones under the hood. Is it possible that the multi switch which controls the lights in malfunctioning?
This is quite dangerous to drive with at night, any suggestions would be greatly appreciated.
Old 04-04-2008, 11:16 AM
ferahgo's Avatar
Default Re: 99 Honda Accord backlight problem (ferahgo)
nobody has any suggestions? I heard good things about this site...
Protosouls
10-20-2011 04:29 PM
myhondasrusty
02-21-2010 06:32 PM
darkchaos
01-04-2009 07:16 PM
ckinne
12-08-2007 06:17 PM
Quick Reply: 99 Honda Accord backlight problem
