Brake line tuck
Brake line tuck
hey guys i just wanted to show you something and see if anyone could give me some insight. Tonight I started my brake line tuck and discovered that my master cylinder from my 94 GSR had two different size fittings. I looked around and found a line that i had yanked off the car that had a fitting that fit the larger hole along with a larger line and what appeared to be a "joint" or adapter. It looks like what appears on number 10 in the picture below. So my question is why isn't it in the brake diagram and in the clutch master diagram?
Re: Brake line tuck (Blahblah718293)
I just took out my abs sys. What i did on the master cylinder, when you are facing it the fitting on the left needs to be bigger, right? Well i found the OEM line for that cut the line and took the fitting off. Put the fitting on my new line. Does that make sense? Are you taking out the abs system? Well there is alot of write ups about the abs sys. You will need a 40/40 prop vlave to.
Re: Brake line tuck (adam081904)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blahblah718293 »</TD></TR><TR><TD CLASS="quote">propably a replaced line for whatever reason, does it have smooth uniform bends like oem?</TD></TR></TABLE>
yeah it's OEM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adam081904 »</TD></TR><TR><TD CLASS="quote">I just took out my abs sys. What i did on the master cylinder, when you are facing it the fitting on the left needs to be bigger, right? Well i found the OEM line for that cut the line and took the fitting off. Put the fitting on my new line. Does that make sense? Are you taking out the abs system? Well there is alot of write ups about the abs sys. You will need a 40/40 prop vlave to. </TD></TR></TABLE>
yeah, I'm eliminating ABS and i have a 40/40 prop valve already. I'm replacing all the lines and using completely new lines and I'm custom routing them
yeah it's OEM
Re: Brake line tuck (vietnamezerice)
I just told you what to do. Find that bigger fitting from the OEM lines, take fitting off by cutting line. Put new fitting on new lines flare lines. There you go problem sloved
sohcturbo92vx
02-11-2012 01:44 PM
IHateJDM
08-23-2005 10:37 AM
sporkcrx
01-10-2003 09:57 AM
