Old 02-22-2008, 09:06 PM   #1
rdemotta
rdemotta's Avatar
Default Engine torque specs JDM B16A ASAP
I need the haed bolts, intake manifold bolts, exhaust manifold bolts, and sequence. water pump tq. specs too. Thanks
rdemotta is offline   Reply With Quote
Old 02-22-2008, 09:17 PM   #2
hott95ej2
hott95ej2's Avatar
Send a message via AIM to hott95ej2
Default Re: Engine torque specs JDM B16A ASAP (rdemotta)
head bolts-step1 22ft lbs step2 53 ft lbs
exhaust manifold 25 ft lbs
just tighten the water pump with out braking the bolts
head sequence go's:
8.6.2.4.10
9.3.1.5.7
Used to be an H22 swap,going back to B-series for life.
Cut and Welded Linkage=Big Mistake
R.I.P. -Brian Wade Arbogast(turbodcx) *You will be missed*
hott95ej2 is offline   Reply With Quote
1992, 2000, 2001, accord, b16a, bolts, civic, head, honda, prelude, pump, sequence, spec, specs, torque, totque, water
