Brake Rotor replacement spec?
Old 02-13-2008, 12:10 PM
propwdialogue's Avatar
Default Brake Rotor replacement spec?
Hey all,
I need a hand from someone with a repair manual. My front rotors are warped and need to be changed, but I want to know whether or not I should replace my rear rotors as well. The info that I'm looking for is the width at which my rotors would need to be replaced.
Also, I'm going to be replacing my pads for mostly street with some auto-x use. Anyone have any good/bad experiences with brembo sport pads?
Old 02-13-2008, 12:11 PM
He knows where you live!
TheMuffinMan's Avatar
Default Re: Brake Rotor replacement spec? (propwdialogue)
Dunno on Brembo pads
Hawks
Cobalt Friction
etc
There's a couple good brands that the AutoX guys do, I believe there's a brake pad discussion in one of the specific forums (might be AutoX)
Old 02-13-2008, 12:30 PM
Derek128's Avatar
Default Re: Brake Rotor replacement spec? (TheMuffinMan)
I got a 94 EX, so I have 1" master cylinder & done ROH
right now I'm using Slotted Brembo blank(98 4cyl accord disk) + Hawks HPS (F&R) for around 8000km or 5000mile
I think HPS is ok for street/daily use
but for auto X i think u need HP plus
never try Brembo pads so can't tell u anything
i order my Brembo blank from this site
its cheap & working fine
http://www.importrp.com/
Old 02-13-2008, 07:20 PM
Default Re: Brake Rotor replacement spec? (Derek128)
I'm thinking the hawks are going to be a bit extreme for my application. Yes, I want track performance, but I'm not sure how much brake noise I'm willing to tolerate on a daily basis.
Anyway, anybody got rotor replacement specs?
Old 02-13-2008, 09:36 PM
Derek128's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by propwdialogue &raquo;</TD></TR><TR><TD CLASS="quote">
Anyway, anybody got rotor replacement specs?</TD></TR></TABLE>
Rear brake Disc Thinkness:
standard: 9.9 -10.1mm (0.39-0.40in)
max refinishing limit: 8.0mm (0.31in)
brake Disc Paralleism: 0.015mm(0.0006in) max
MILANO_RED_CL9
Acura TSX
10
09-29-2010 04:58 AM
MILANO_RED_CL9
Suspension & Brakes
09-17-2010 11:08 AM
Eucalyptus lude
10-06-2004 04:06 AM
erniecars
07-11-2002 08:35 PM
Weston
06-20-2002 09:56 AM
Quick Reply: Brake Rotor replacement spec?
