drivers side floorboard sopping wet?! need help
Old 02-10-2008, 01:11 PM
singlecamslam98's Avatar
Default drivers side floorboard sopping wet?! need help
well just like the title says ever since about 4 months ago i get in my car and the floor would be sopping wet. id vacuum it up and it would just keep getting wet everytime it rained. its a 98 coupe with no rust but it has been in an accident but it never use to get wet inside after the accident so i dont think its that. i thought it might be the sealant on the windshield because ive heard of cases where thats happend but i got the windshield replaced because it was cracked and it still does it. i checked the moonroof and thats not leaking. i took off the drivers side kick panel because it seems like it gets more wet in the front and i had my dad pour water down the windshield and i could see a bit of water dripping down some wires that were way up there but i couldnt see where it was exacally where it was coming from. does anybody have any ideas its driving me nuts and its ruining my car at the same time.
Old 02-10-2008, 01:26 PM
CiViCBruh's Avatar
Default Re: drivers side floorboard sopping wet?! need help (singlecamslam98)
i have the same problem accept the wetness is on the passenger side and i do have a cracked windshield and the crack is on the passenger side but if you do figure it out let me know thanks
Old 02-10-2008, 01:30 PM
l337m4n's Avatar
Could it be something in the firewall area?Maybe a bit of rust where the water runs down off the wind shield?
Old 02-10-2008, 01:42 PM
ekb16's Avatar
could be that ur evap is plugged up
Old 02-10-2008, 01:43 PM
Default Re: (l337m4n)
i told the guy that was replacing my windshield to look for stuff like that and he said he didnt see anything or any signs of it leaking so i dont think its that. i have a small hole drilled in one of the plugs in the firewall for my boost and oil pressure guage but ive never seen water coming from that.
Old 02-10-2008, 02:15 PM
Default Re: (ekb16)
how would the evap make inside the car wet? and wouldnt it smell like gasoline.
Old 02-10-2008, 02:17 PM
Panda Eg6's Avatar
Default Re: (singlecamslam98)
Wierd i have the same problem, its right under the drivers floor mat... i dont get it
Old 02-10-2008, 02:53 PM
mastakmk's Avatar
Default Re: (Panda Eg6)
uhh i opened my car door the other day.. and the floor was wet. dunno how it happened it was a rare occurance. my windshield leaks at the top.. but not near this part.. this happened on the drivers side near the seat. but my seat was not wet.. LOL.. uhh. i will check it out in more detail when its warm.
Old 02-10-2008, 03:47 PM
Aludew5's Avatar
could potentially be a seat on firewall. there are several wires, rods, etc that run through it. on my friends car we had to basically cover the top half of the firewall w/ bondo and that rubberized coating spray. do you have an after market stereo? if you drilled through the firewall hooking up ur amp it could be leaking there too.
Old 02-10-2008, 03:58 PM
Default Re: drivers side floorboard sopping wet?! need help (Aludew5)
from what im thinking it is coming from the firewall since i have seen water dripping down some wires along the uper left side of the firewall but its almost impossible the get to those wires let alone see whats above them. id prabably have to take out the dash along with other things so i want to make sure thats what it is. ive contemplated selling my car for this reason alone it is seriously driving me nuts
Old 02-10-2008, 05:27 PM
VTDr0p0ut's Avatar
Could it be the trim below the windshield wipers broke on you, possibly during a windshield replace, wiper replace, or anything else you would remove that piece for? I've never had that happen on my eg, but on some other cars... not 100% sure if that dumps into the cabin or not.
Old 02-10-2008, 06:48 PM
Aludew5's Avatar
just take out the carpet halfway and seal out every possible spot you see underneath. you'll probably get where the water is leaking in even if you don't specifically see a hole. if not, you're only out 5$ on a can of rubber spray crap and 10 mins of ur time. it might keep you from selling ur car! or could mean you get more money out of ur car when you do decide to sell because ur interior won't be rotted out. lol
Old 02-11-2008, 03:29 AM
anybody else have a solution?
Old 02-11-2008, 06:46 AM
Civic9390's Avatar
Hmm Windshield seal... Only other thing is maybe condensation from under the car but im not sure...
Old 02-11-2008, 10:34 AM
ekb16's Avatar
i was actually referring to the evaporator not the evap canister...have u noticed that when u turn on ur a/c in the summer time that there is drips of water from under the car from a tube..well usually if that tube gets plugged up and the condensation from the evap doesnt have anywhere to go it will leak into the passenger side carpet area
Old 02-11-2008, 10:54 AM
EGJason's Avatar
Default Re: (ekb16)
There's a leak problem with the EH adn EJ chassis due to insufficient sealer on the seam at the firewall. Not sure if this probelm stretched to the EK chassis or not.
Just re-seal everything at the firewall.
Old 02-11-2008, 11:12 AM
Default Re: (EGJason)
i dont have ac i took it out all the way up to the firewall, but yea it looks like im gonna have to try and reseal everything on the firewall on the drivers side : (. is it pretty hard to take the dash out?
Old 02-11-2008, 11:45 AM
ekb16's Avatar
Old 02-11-2008, 12:11 PM
antiguru's Avatar
Default Re: (ekb16)
i had this happen after a car wash but in that case the cause was pretty obvious =p
Old 02-11-2008, 12:16 PM
azn_88's Avatar
Default Re: (antiguru)
check your fenders and firewall area for any leaves and other things blocking the draining of the water from the top of the car to the bottom of the car. happened to my friend's dc2 and once he cleared thats stuff out of the bottom there was no more water inside the car.
Old 02-11-2008, 01:01 PM
Default Re: (azn_88)
thanks ekb16 but the leak is only on the drivers side
Old 02-11-2008, 02:52 PM
ekb16's Avatar
mybad missed the driver side kick panel part
Old 02-11-2008, 03:08 PM
jdmboss's Avatar
ZIEBRAT just take your civic there
Old 02-11-2008, 03:16 PM
mastakmk's Avatar
Default Re: drivers side floorboard sopping wet?! need help (jdmboss)
are you missing your splash guards??? i am.
Old 02-11-2008, 03:19 PM
Default Re: drivers side floorboard sopping wet?! need help (mastakmk)
yea i am but ive been missing them for awhile and it just recently starting doing this, but thats definetly an area ill check out. right now the floor is just completly frozen so its hard to tell if its leaking anymore
Quick Reply: drivers side floorboard sopping wet?! need help
