Wiring Diagram for the Ignition System
Old 01-27-2008, 07:55 PM
LOC714's Avatar
Default Wiring Diagram for the Ignition System
Issue: Fuel is priming, but no spark -new dizzy. This is for d15b engine in an EG.
Old 04-15-2008, 08:42 PM
035psi's Avatar
Default Re: Wiring Diagram for the Ignition System (LOC714)
did you ever solve your problem ????? I`m having the same issue now. PM me if you can.
Old 05-30-2008, 05:24 PM
Upper Hand's Avatar
Default Re: Wiring Diagram for the Ignition System (035psi)
Im having the same issue..can both of u pm me if possible??
Old 05-30-2008, 06:10 PM
Former User's Avatar
Default Re: Wiring Diagram for the Ignition System (Upper Hand)
Is the distributor getting battery voltage?
Check the connection of the ground wire attached to the thermostat housing.
Check for blown fuses.
Old 05-30-2008, 10:31 PM
Upper Hand's Avatar
Default Re: Wiring Diagram for the Ignition System (RonJ@HT)
midnight bump!! lol
all fuses good,ground by thermostat good..dizzy is getting 12.6V
Does someone have a pinout for the big dizzy plug?
Modified by Upper Hand at 12:02 AM 5/31/2008
Old 05-31-2008, 04:33 AM
Is the coil and igniter new?
Old 05-31-2008, 10:50 AM
Upper Hand's Avatar
thanks for the diagrams..
no coil and igniter are from a obd1 dseries that was running..I repinned the big plug and used the internals from the D in my base..
still same result..cranks,can smell fuel in chambers,sometimes has spark sometimes doesnt..
Old 05-31-2008, 11:03 AM
I would think that the coil and igniter are your main suspects.
Old 05-31-2008, 01:59 PM
Upper Hand's Avatar
yea thats my thought too but i dont really wanna buy a new dizzy its $681...i rebuilt the original one with the guts from a obd1 D-series dizzy i had lying around,repinned the big plug.still no luck..
Old 04-25-2021, 05:29 PM
Will_ek's Avatar
Is there someone who coule help me, same problem. Car was running then slowly died. Replaced dizzy/ with new coil and icm. Crank no spark. Fuel pressure all good thermostat ground good. Swapped the car and still have the same engine even with a new engine wiring. Bserie ek hatch 1999
Old 04-29-2021, 02:45 PM
muellersfan's Avatar
Check fuse 9 and whether battery voltage reaches the coil and ICM. If those are fine, check whether the timing belt stripped or snapped. Then go from there.
Samuel Nichol
10
10-26-2022 04:04 PM
96ludedude
04-18-2010 05:43 PM
samco
10-02-2005 04:47 PM
ITRnorway
05-18-2005 11:33 AM
ludedudeh23
07-06-2004 09:56 AM
Quick Reply: Wiring Diagram for the Ignition System
