EK3 OBD2/DLC connector location?
Old 11-21-2007, 05:08 PM
KoRn_vIRuZ's Avatar
Default EK3 OBD2/DLC connector location?
Hi everyone,
I'm going crazy because no matter how much I look, I can't seem to find the DLC/OBD2 16pin plug on my EK.
I looked under the driver's side dash but came out empty handed. Can anyone give a a clear description (color, relative location to other components such as the fuse box, etc) or maybe post a picture? I'd really appreciate it.
The only thing I found that was vaguely similar to an OBD2 connector was this:
It is behind the left kick panel and bolted to the car so I couldn't get it out. Could it be?
KoRn_vIRuZ is offline
Old 11-21-2007, 05:39 PM
bittles110's Avatar
Default Re: EK3 OBD2/DLC connector location? (KoRn_vIRuZ)
There might be a little label describing where the DLC is on the bottom side of the steering column... Try that.
bittles110 is offline
Old 11-22-2007, 11:27 AM
KoRn_vIRuZ's Avatar
There is one label saying "check your service manual". But the manual does not give a precise location.
Help appreciated!
Old 11-22-2007, 11:31 AM
tofast2belast's Avatar
look where the fuse box is under the dash its right in front of that. at least thats where mine is
tofast2belast is offline
Old 11-22-2007, 01:11 PM
KoRn_vIRuZ's Avatar
I can't find it... What color is it? Is it protected by a cap or something?
Thanks.
Old 11-22-2007, 02:46 PM
RyanA's Avatar
Default Re: (KoRn_vIRuZ)
Should be straight above the hood release handle pointing straight down. It will be the normal D shaped OBD2 port.
The piece you have pictured is the grounding junction block.
RyanA is offline
Old 11-22-2007, 03:00 PM
KoRn_vIRuZ's Avatar
Default Re: (RyanA)
Thanks Ryan.
But it just isn't there.
This is how it looks like:
Could my 97 EDM EK3 be OBD1 or something?
Old 11-22-2007, 04:10 PM
KoRn_vIRuZ's Avatar
Things are starting to look ugly.
Just like this guy with a 98 EDM CRV, I can only find the 2 and 3 pin blue connectors next to the ECU.
I saw this 3 pin to 16 pin adaptor on eBay... I wonder if that will give me full OBD2 functionality?
http://cgi.ebay.com/HONDA-3-PI...wItem
Modified by KoRn_vIRuZ at 2:18 AM 11/23/2007
Old 03-06-2008, 05:40 AM
civic_ek3's Avatar
hello there,
i got a same problem with you.
what is your solution?
by the way where is the 3 pin connector?
civic_ek3 is offline
Old 03-06-2008, 06:07 AM
draneusmc's Avatar
Hope this information is helpful. I pulled it from the manual.
draneusmc is offline
Old 03-07-2008, 03:21 AM
civic_ek3's Avatar
Default Re: EK3 OBD2/DLC connector location? (draneusmc)
thanks dude...
i will try to look it tomorrow since now it already dark in Malaysia
==> try look it just now. but it fail. not there...
now what shall i do... where is the exact location of the connector....
Modified by civic_ek3 at 3:00 PM 3/7/2008
Old 03-10-2008, 01:33 PM
KoRn_vIRuZ's Avatar
Default Re: (civic_ek3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_ek3 &raquo;</TD></TR><TR><TD CLASS="quote">hello there,
I came to the sad conclusion that EDM EKs weren't equipped with OBD2 connectors. Or at least my 97 isn't.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">
by the way where is the 3 pin connector?</TD></TR></TABLE>
It's on the right side of the car, close to the ECU.
Old 03-10-2008, 01:50 PM
H-T White Ops
NOFX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KoRn_vIRuZ &raquo;</TD></TR><TR><TD CLASS="quote">
It's on the right side of the car, close to the ECU. </TD></TR></TABLE>
I'm pretty sure there is no DLC on the EDM models.
https://honda-tech.com/zerothread/2229150
NOFX is offline
Old 02-22-2014, 08:23 PM
honda4ali's Avatar
Honda Civic 97 has 3 pin DLC connector and 2 pin SCS connector, for OBDII advantage we need 3 pin to OBD-II adaptor cable.
If anyone can find out the availablity in pakistan, then please do let me know. or if anyone found another solution to OBDII for honda then do me a favor too, pls.
honda4ali is offline
Old 02-23-2014, 02:08 AM
If you loved me, you'd all sell me your magic cards to me today
doctorake's Avatar
Start a new thread.
doctorake is offline
moyer02
03-19-2018 05:17 PM
b17itr
07-13-2009 04:34 PM
dano18
Honda Civic (2001 - 2005)
06-05-2009 08:46 AM
kelviiv
04-12-2008 12:11 AM
Quick Reply: EK3 OBD2/DLC connector location?
