SRS Light
Old 11-12-2007, 09:59 AM
caverspencer's Avatar
Default SRS Light
My SRS is on in my 2 door 1997 Honda Accord EX 4cylinder 2.2L VTEC Manual transmission.
Any guesses what it might be?
Is there a way to read a code for the SRS like there is for the Check Engine light?
Old 11-12-2007, 11:18 AM
kildar's Avatar
Default Re: SRS Light (caverspencer)
they have a read out system at auto zone, I dont know if it does anyhting for your srs light. It might just want you to put on your safety belt, or your passenger too. Or you might need to replug a wire under the seat.
Old 11-12-2007, 12:40 PM
Default Re: SRS Light (kildar)
I ran to Checker during lunch. They have the ODB2 reader but they say it doesn't read the SRS codes and I need to go to the dealer for the SRS light.
Can I do the trick of jumping the blue clip under the glove box and counting the flashes when turn on the ignition? If so where can I find a list of what the codes mean?
Old 11-12-2007, 01:36 PM
quality_shit's Avatar
Have u by accident unplugged the SRS fuse by any chance? I unplugged mine for about half a second one day and the light stayed on indefinetly until I reset it. I would try re-setting it and see if it comes back on. ITs very simple just search for the instructions to reset the SRS. Make sure to use the jumper with the small yellow plug instead of the big one. Worked for me. NO MORE SRS LIGHT>
Old 11-12-2007, 01:51 PM
I ran out and took some pictures.
If I jump the blue connecter will it give me the codes?
Old 11-12-2007, 01:55 PM
Default Re: (quality_shit)
How do I reset it? That could very well be the problem.
Old 11-12-2007, 02:22 PM
He knows where you live!
TheMuffinMan's Avatar
battery
remove it should get rid of the light, but you may have a legit problem
Old 11-12-2007, 02:30 PM
Default Re: (TheMuffinMan)
I must have a "legit problem" then. The battery was out for 8 days last week while I replaced the water pump, timing and balance belts etc...
The light has been on since long before any of that happened.
I still havent been able to find a list of trouble codes. I have a bad feeling I may have to bite the bullet and go to the dealer.
Old 11-12-2007, 02:40 PM
Okay I believe its SRS code #92
I jumped the blue clip. It had nine long illuminations folowed by two short ones.
Any idea what code 92 is?
Old 11-12-2007, 06:41 PM
Default Re: (caverspencer)
SRS Code 92 is "Faulty SRS power supply system"
I spent a couple of hours and went through every bit of wiring I dared and checked for blown fuses, proper voltage and tight connections. Everything seems normal.
Does anyone have any ideas????
PLEEEEEEEEEEEEEEEEAAAAAAAAAASSSSSSSSE Help!!
Old 11-13-2007, 07:30 AM
HondaAccordTdR's Avatar
You may have a legit problem. I would take it to a stealership or a trusted mechanic, they would know for sure. I think 5th gens had a recall on the SRS system... someone correct me if i'm wrong.
Old 11-14-2007, 07:55 AM
mapleshade's Avatar
Default Re: (HondaAccordTdR)
Where did you find the codes? Mine is "85", but I haven't been able to find what the code is.
Old 11-14-2007, 01:33 PM
jmk64's Avatar
I believe the only way to reset the SRS light (without the dealerships intervention) is to follow this.
https://honda-tech.com/zerothread?id=1422442
Disconnecting the battery won't do it (been there tried that).
My SRS light comes on about once every 3 months or so. More often since I installed an under sized battery. I believe any little power glitch in the electrical system will trip the SRS light to come on. Mine seems to only trip when starting the car.
Anyway , Good Luck
Old 11-14-2007, 06:11 PM
PnX-R's Avatar
Hmm.. That's a different code.. Anyways, the biggest issues I've seen with that generation is a worn out battery will turn that light on. In your situation, I would just throw on some jumper cables and connect it to another car that's running. Turn the key to the "ON" position, the SRS unit will do its self check and if it passes, the light will turn off.. And if it does, it's your battery..
As far as clearing the code, I usually use the scanner.. When in doubt, take it to the pros...
Old 11-15-2007, 12:10 PM
josephcitr's Avatar
if you jump the blue connector (two pin ) it should flash a code
hit me up with the code and i can tell you what it means jrcitro@hotmail.com
Old 11-15-2007, 02:10 PM
Default Re: SRS Light (josephcitr)
Joseph,
I posted this above but you must not have seen it:
Old 11-16-2007, 07:08 PM
fatheadon1's Avatar
http://www.geocities.com/myintegra96/srs.html
Old 11-16-2007, 07:42 PM
prelude_93vtec's Avatar
92 -Evaporative Emission Control Systemp-insufficient purge flow
you got another problem there buddy. the blue wire only shows CEL not SRS or anything. check all your wiring
Old 11-16-2007, 08:51 PM
Default Re: SRS Light (prelude_93vtec)
the 92 is the SRS light code not the check engine light. Jumpering the blue does retrieve both the check engine light codes and the SRS light codes.
In this case the 92 is Nine long flashes then two short flashes of the SRS light.
Old 11-17-2007, 08:06 AM
interesting
Old 11-17-2007, 01:42 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by caverspencer &raquo;</TD></TR><TR><TD CLASS="quote">SRS Code 92 is "Faulty SRS power supply system"
If there are no blown fuses, (under dash or under hood) Try resetting the system using the mes procedure. Does it recode?
PaulRi
12-08-2015 05:29 PM
Janet1995
10-08-2010 09:41 PM
undrh2o
10
12-19-2009 11:42 AM
Caveman74
10-30-2006 02:55 PM
lv6l
Honda Civic (2001 - 2005)
10-27-2006 08:13 PM
Quick Reply: SRS Light
