SPA Topmount Cast Turbo Manifold. Let me know your experience please
#351
spa manifold
i have one on my built gsr. i have a holset hx35. dynoed at 464hp. 16psi. 1000cc ID. l'm going to upgrade my turbo soon and possibly manifold.
anyone else have experiences with this manifold?
#354
#358
Moderator
Re: SPA Topmount Cast Turbo Manifold. Let me know your experience please
This question is vague and silly.... please redeem yourself by specifying what you're trying to do with your car and what turbo you think you're trying to put in this thing..
I.e. "I have XX turbocharger / kit in my 94-01 Integra... I want to make XX power, (or fly to the moon.. whatever)... what manifold and turbo combination holds the largest housing sizes from ANY of the major companies?"
#359
Seeing as how this is the SPA topmount thread, I think it's okay to assume he was asking about this manifold.... If not then it is the most rediculous questioned asked in a while
#362
Moderator
Bah..
#363
Retired Moderator
well, ive had 2 spoolin log manis crack and 2 go-autoworks log manis crack on me..
after spending over $1200 just on manifolds/re-fabbing and alternate transportation, im tired of having to replace them. since replacing these logs, i have 1 stripped exhaust mani hole and now need to helicoil it which now i have to spend more $$ cuz of cracking manifolds.
Cheap ebay casts suck, but i havent had to deal with cracks. just really tight to access turbo bolts.
#364
Moderator
I don't think its every company that's wrong. There may be something going on that you might not be seeing in your setup. I mean; after going through that many manifolds, I would tend to believe that SPA wouldn't be the solution, and that something else might be going on..
Just an idea, I guess... A different frame of reference.
#367
I dont think there is anything special about it and agree that the same power can be made on a cast log, tubular log etc. Its really just the bling factor of the top mount and ease of working on it if need be. the clocking flange isnt needed to run this manifold, just makes fitment of dp a little easier and turbo is all
#369
Moderator
For example, the use of a Pandusky-made clocking flange (https://honda-tech.com/forums/forced-induction-16/spa-top-mount-cast-manifold-crx-2242460/ ) is essential to fit in some vehicles such as EG hatchbacks and CRXs, in order to even close the hood properly, or keep A/C compressors and other amenities it claims to fit with it just out of the box.. (See Page 9 of this thread). Turbo-LS, you said it yourself that a need of this flange exists when you attempted to mass produce it and create a group buy of this clocking flange in order to make any turbos fit properly.. Did it just magically start to fit on all the turbos now? C'mon.. stay consistent my friend... Either you need the clock flange, or you don't... which is it?
(See page 10-11 on this thread.. Turbo-LS's attempt to have the clocking flange mass produced...https://honda-tech.com/forums/showth...147408&page=11).
BTW, this is no attack against you, Turbo-LS in anyway. I'm just pointing out that its silly to get this thing to work properly when 3 years ago people swore it was the new hotness. Despite Turbo-LS's attempt to help fill a gap in the market for these things, there still wasn't enough interest due to these overlaying concerns..
You then have silly fitments like this for the GT35R or SC61s with even E-covers: (From Boosted_B_Series)
SERIOUSLY!?!?!?
This last one just looks like complete ***.. Poor CF hood
with the user's personal testimony . This is enough to give me caution as to its repeatability of results or fitment
I had the 60-1 on the SPA...
It will not fit a 35r however...
I've tried both..
The center section is narrower on the 35r so the exhaust and compressor are closer together and the compressor hits the exhaust runner.
I loved my spa topmount but got rid of it because of the 35r issue.
I've tried both..
So, I apologize if I seem to be the "negative nelly" in this, but its not without merit, and I'm not talking out of my *** to "hate" on another product that isn't more "traditional". If SPA can't even make their own clocking flanges to work with their exhaust manifolds and other products, or have at least the wherewithal to help locate some of the niche parts needed to make it work, (possibly including tech support as to how one should fabricate a downpipe to fit this unique configuration).. Why the hell should I believe in it?
I'm sorry.. I'm just not convinced otherwise.
#371
I see your point, yes not all cars will it fit properly without the clocking flange. i completely agree but some it will. yes its silly to get extra things to make it fit but then again most setups need extra things to make stuff fit in general BUT a quality tubular manifold will work well then you forgo other things. its all a balance i guess and what someone wants in their car.
Im running an E cover t3/t4 with the clocking flange and it works just fine in my DC chassis. With room for an S cover as well but very tight fitment . Im in no way trying to say this manifold is choice over any other. I just like it thats all and it works well with the flange lol
#372
Moderator
#374
Well I just read this whole thread and I Am on a budget so I'm going with this manifold for sure now,it will be for a b16 crx.
#375
Moderator
But this is what keeps 'em comin'...Someone always trying to ice skate uphill thinking they have a cheaper workaround... my god.
