98 civic need to reset the computer
Old 10-02-2007, 03:59 PM
C_R_X_'s Avatar
Default 98 civic need to reset the computer
have a 98 ex and i just swapped in another d16y8 and was told i need to reset the computer before i smog it. They also told me to reset it i need to do simple driving tasks like go from 0-40 quickly and then slowly go to 60 and then stop....... things of that nature anyway it all sounded pretty weird to me any idEAS?
Old 10-02-2007, 04:00 PM
Ron454321's Avatar
Default Re: 98 civic need to reset the computer (C_R_X_)
Unlpug the ECU, or you can take the ground off the battery for 10-15 min.
Old 10-02-2007, 04:27 PM
C_R_X_'s Avatar
Default Re: 98 civic need to reset the computer (Ron454321)
thanks that is what i thought ...........i just wanted to know if anyone had heard what i mentioned above
Old 10-02-2007, 04:40 PM
Darth ModerVader
Padawan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by C_R_X_ &raquo;</TD></TR><TR><TD CLASS="quote">thanks that is what i thought ...........i just wanted to know if anyone had heard what i mentioned above</TD></TR></TABLE>
I've heard of situations where the ECU will read "not ready" or something to that effect. Basically, you just want to drive the car a decent amount before taking it in for testing.
Old 10-02-2007, 04:51 PM
stock_honda_coupe's Avatar
Default Re: 98 civic need to reset the computer (Padawan)
In OBD2 land, when you clear a the computer like that, you clear all the "readiness tests". These are things that the emission testing people look at before testing. If the computer shows them as incomplete, they won't do the emission test. Certian test are stuff like Cataletic performance, Evap leak test, O2 sensor proper operation, and so on. The computer needs to retest all this before you take the car in for emission testing. Some of these tests need you to drive at certian speeds for so long, so much time between engine shut off and start up, things like that.
Old 10-02-2007, 05:59 PM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">
I've heard of situations where the ECU will read "not ready" or something to that effect. Basically, you just want to drive the car a decent amount before taking it in for testing.</TD></TR></TABLE>
There's something called I/M monitors.
Think the '96-'00 has about 6 or 7.
They're stuff like monitoring catalyst efficiency, O2 sensor readiness, stuff like that.
If you reset the ECU all of that **** "resets" - and takes some mileage & driving to "learn" the data back again.
If you unplug your battery right b4 u go to the inspection station then they'll read all your I/M monitors as not ready and it'll be pretty obvious as to why. They don't take that long to reset - but you have to ask yourself if the CEL will come back on in that time frame.
It's usually anywhere from 20-80 miles, but I've seen 'em take as long as 200 miles for all to ready again.
EDIT:
What they told you was right, there's a whole list of "ways to drive" so your I/M monitors ready faster...but regular driving will ready then eventually too.
Old 10-02-2007, 06:38 PM
Ron454321's Avatar
This is why I drive OBD-I
allvtecyo
Engine Management and Tuning
08-08-2014 06:04 PM
CivicHonda98
04-02-2014 05:14 AM
zerovandez
02-13-2007 07:58 PM
flood
07-14-2005 01:24 PM
opkjoblacsh
12
09-29-2004 05:05 PM
Quick Reply: 98 civic need to reset the computer
