> Acura Integra
Old 07-27-2007, 12:28 PM   #1
94DC17
94DC17's Avatar
Send a message via AIM to 94DC17
Default 1994 acura integra idle fluctuating?
I need some help please.. I replaced the idle air control sensor and my idle still goes up and down from around 1500 to about 3000RPM's. I dont know what else it could be, some one told me it could be TPS or vacuum line but i dont know.. so please help me out.
thank you
94DC17 is offline   Reply With Quote
Old 07-27-2007, 12:54 PM   #2
St Jimmy
* B A N N E D *
Default Re: 1994 acura integra idle fluctuating? (94DC17)
You have a vaccum leak or bad ground.
St Jimmy is offline   Reply With Quote
Old 07-27-2007, 12:55 PM   #3
LordAphotic
LordAphotic's Avatar
Send a message via AIM to LordAphotic
did you recently replace the intake manifold ?
Freedom comes in only one form... Absolute.
Make your car work for you, Dont work for your car(debt).
LordAphotic is offline   Reply With Quote
Old 07-27-2007, 01:08 PM   #4
94DC17
94DC17's Avatar
Default Re: (LordAphotic)
I haven't replaced the intake manifold and what kind of ground would i be looking at?
Also how would i check for leaks?
thank you,
Old 07-27-2007, 01:55 PM   #5
hard charging 929
hard charging 929's Avatar
Default Re: (94DC17)
air leaks from the throttle body or intake manifold gasket or any of the air lines running off the intake mani. wil cause a vacuum leak.
What year is your car and have you reset your ecu lately. If you have or if your battery went dead or I believe just over time you need to adjust your idle. If you idle is set too high it will cause a surge. You can try to lower it down and see what it does. There's a screw on the throttle body, use a flat blade screwdriver and turn it. You'll hear the engines rpm's lowering or rising, try and lower it down to I wanna say stock is 750 rpm +/-50 rpms. See if it's a simple idle adjustment or if it's something else. Also, you want to check your fast idle valve. Look in some of the FAQ threads for write ups and more info.
Hope it helps
Beat and burn your local car thieves!!!!
Two Wheeled Monsta
'08 Si Sedan
Status: All stock for now...
http://is.rely.net/1-92-29998-l-1gbM...AmVuBW3hGg.gif
hard charging 929 is offline   Reply With Quote
Old 07-27-2007, 03:01 PM   #6
94DC17
94DC17's Avatar
Default Re: (agoldenau)
I checked most of the gaskets and they weren't leaking. I also checked all the lines to see if they were plugged in and they were. I'm reseting the ECU to see if that will do anything.
Old 07-27-2007, 04:37 PM   #7
94DC17
94DC17's Avatar
i took off my fast idle control valve and i don't know if it is supposed to move around in there can anyone let me know thanks..
Old 07-28-2007, 11:02 AM   #8
hard charging 929
http://honda-tech.com/zerothread?id=699787
Two Wheeled Monsta
'08 Si Sedan
1994, 1998, 94, 95, acura, adjust, adjustment, air, ajustment, controller, fluctuating, idle, integra, jimmy, st, surges
