02 Accord Alignment Specs
Old 07-11-2007, 07:22 AM
dobiechris's Avatar
Default 02 Accord Alignment Specs
I have just installed some Tanabe DF-210 lowering springs and went and got an alignment. The rear needs to be adjusted, so I have ordered an Eibach Pro Alignment Kit. I am trying to figure out what settings to put it at to match the OEM set-up.
Old 07-11-2007, 10:15 AM
PatrickGSR94's Avatar
Default Re: 02 Accord Alignment Specs (dobiechris)
Why did you need this aftermarket alignment kit? Do you have bent suspension components? If it's just for camber correction then it's probably not actually needed if you just get the toe set to 0, making sure that thrust angle is as close to 0 as humanly possible, and rotate the tires regularly.
But as for settings, it would have to be on an alignment rack to set it up properly, unless you have camber gauges to use for DIY alignments.
Old 07-11-2007, 12:06 PM
dobiechris's Avatar
Default Re: 02 Accord Alignment Specs (PatrickGSR94)
The guy at the alignment place said that the rears do not have an adjustable camber feature, also his records show no settings for the rear, since his information comes from the factory settings recommendations. He sais that he adjusted the toe as much as possible, but the tires still tilted in from the top.
Old 07-11-2007, 12:39 PM
As long as the toe is adjust to 0 (or factory spec) then you shouldn't have any problem with camber in the rear.
Most of these guys doing alignments are either clueless or trying to make a buck selling extra parts.
Old 07-11-2007, 03:42 PM
02 accord's Avatar
The 02 accord comes from the factory with -0.5 deg camber in the rear.
Old 07-11-2007, 06:50 PM
Default Re: 02 Accord Alignment Specs (02 accord)
yeah, most cars do, to maintain a tendency to understeer for safety purposes. A little more negative camber won't hurt anything, as long as the toe is zero'd out.
Old 07-11-2007, 08:07 PM
dobiechris's Avatar
Thanks for the info guys, this forum is great help, thanks to people like you guys.
jdmztrane
07-19-2008 06:20 AM
redDAinteg
04-29-2008 06:30 AM
RallyRedGT-V6
05-19-2004 04:00 AM
evowu
01-23-2004 09:02 PM
dre000
03-10-2003 11:41 AM
Quick Reply: 02 Accord Alignment Specs
