2004 TL - How do I reset my "Check Engine" light?
Re: 2004 TL - How do I reset my "Check Engine" light? (nikkums1021)
I believe most autozone stores will scan a CEL free of charge. I assume they would be able to reset it with their scan tool if you ask them.
Re: (ITR640)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR640 »</TD></TR><TR><TD CLASS="quote">I may be wrong but cant you scan through your info displaty by the guages using your info button and reset it?
if not go to the dealer</TD></TR></TABLE>
You can reset the so-called "maintenance minder" system that way, but not the check engine light.
#1 Super Guy
Some autoparts stores will let you use the scan tool and erase your own codes. Autozone by me wouldn't, but O'Reilly Auto does.
BTW: For future searchers, here is how you read the flashing D-light or Check Engine Light codes without an OBD2 or Honda scan-tool (OBD2 scanner can't pull D codes anyways). You still need a scan tool to delete CEL codes...
Originally Posted by 94eg!
Just grab a paper clip and read the codes yourself. Stick the paper clip in the DLC by the drivers right knee (as shown in this picture). Then switch the ignition to the "ON" position and watch all the lights start blinking. Long blinks are 10's & shorts are 1's. Just add them together to get the code for that light. If there is more than one code stored, they will be separated by a break between blinks:
This link has the definition for all check engine light blink-codes:
K20Tuned LLC*::*DC5/EP3 Codes
And here is a link to show the Transmission "D" light blink-codes:
http://www.piloteers.org/forums/14-p...tml#post387236
Write down all your codes and come back to THIS thread and let us know.
also just an addition to this thread a lot of people think you need to go buy a fancy/expensive scan tool to read/clear code. You don't, just go onto ebay and buy a ten dollar obdII bluetooth tool compatible with torque which is an app. It will be able to show you ten times more than what an actual scanner would. This includes things like a graph of what voltage each of your o2 scanners is reading and tons more, basically if your ecu monitors it, it can tell you what the ecu is reading. I just have the free version of the app but for $5 you get a ton of options.
