How to adjust the a/c belt tension
Old 06-24-2007, 08:09 PM
joeEK00EX's Avatar
Default How to adjust the a/c belt tension
Hey well I have a problem with my D16Y8 it makes a noise when I turn on the A/C in my 00 EK EX so I'm guessing is my ac belt how do I tighten it up can you guys help? TNX
Old 06-24-2007, 08:49 PM
Global Moderator
tech8's Avatar
Default Re: How to adjust the a/c belt tension (joeEK00EX)
The noise you are hearing is not a growl, right? If it is, it may be a bad A/C Idler Pulley Bearing. Here is a TSB:
http://www.tegger.com/hondafaq...e.pdf
But, to answer your question on how to adjust the A/C belt tension:
(Use the image in the TSB as a guide, so you know which is the pulley center nut, and which is the adjusting bolt.)
1. Loosen the center nut on the pulley (Loosen, don't remove).
2. Turn the adjusting bolt to get proper tension.
3. Re-tighten the center nut on the pulley.
Old 06-24-2007, 11:23 PM
joeEK00EX's Avatar
Default Re: How to adjust the a/c belt tension (tech8)
Hey thanks bro preciate noise is gone.
On1wheel
12-28-2018 08:44 AM
zx92027xz
08-22-2010 07:51 PM
civic=goodgasmileage
Honda Civic (2001 - 2005)
06-06-2010 08:39 PM
Riptide_NVN
04-07-2009 08:41 AM
Quick Reply: How to adjust the a/c belt tension
