Is it possible to disable the 98 accord demobilization security system??
Old 06-16-2007, 04:42 AM
RochesterD16T's Avatar
Default Is it possible to disable the 98 accord demobilization security system??
Hello all....wife lost the only key that will start her 98 accord - it has the demobilizaiton system in it, we had a key made a while back what will open the car door but it will not start the engine ofcourse.
So before i pay honda 115 dollars for a new key and to reprogram it i am wording if that system can be disabled, don't think its possible but it never hurts to try.
Thought about getting a ignition system from the junk yard, but that probably wouldn't be any cheaper anyway....
Old 06-16-2007, 06:09 AM
Default Re: (Evil Monkey)
Figured as much....have the apt. setup already anyway....thanks
Old 06-18-2007, 03:06 AM
thanks guys was able to get it done at honda on saturday, only cost 50 dollars for the key and they programmed it for free, not to sure if i got away w/ it or not but as soon as he said i was all set i was outta there.
funny thing is the guy who found the keys to the car out side our apt. turned them in right after i got that done and the old key doesn't work any more so idk they must have whipped the system clean...would like to have two keys anyway so i'll be going back to see if they can get the ecu to recognize both.
Old 06-18-2007, 05:12 AM
YeuEmMaiMai's Avatar
Default Re: (RochesterD16T)
I believe that there is either a 4 or 6 key limit
Old 06-18-2007, 05:26 AM
Global Moderator
tech8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RochesterD16T &raquo;</TD></TR><TR><TD CLASS="quote">
funny thing is the guy who found the keys to the car out side our apt. turned them in right after i got that done and the old key doesn't work any more so idk they must have whipped the system clean...would like to have two keys anyway so i'll be going back to see if they can get the ecu to recognize both.</TD></TR></TABLE>
Yeah, the dealer probably deleted the lost key, and they could add it back. There is a 6 key limit. Here is a TSB FYI:
http://www.tegger.com/hondafaq...e.pdf
Lori Jordan
07-05-2018 07:43 AM
vraptor
08-22-2017 11:50 AM
L0L59
Audio / Security / Video
07-11-2017 08:10 AM
Low_bias
08-21-2011 10:14 AM
monkeyMojo
03-23-2004 09:48 PM
Quick Reply: Is it possible to disable the 98 accord demobilization security system??
