D16Z6 VTEC Pressure Switch wire color
Old 06-09-2007, 08:56 PM
Aquafina's Avatar
Default D16Z6 VTEC Pressure Switch wire color
What are the colors of the VTEC Pressure Switch wires on the plug? 96 DX with Z6 head and ECU (Boomslang harness). I cut the clip off a 92-95 VTEC engine harness. It was the only green plug that would fit the Pressure Switch. Has blue/black and solid black wires.
I just need to know if its the right clip, and what color wire goes to the ECU. I have the solid black going to the ground on the thermostat and am throwing CEL 22. Yes, I've searched, a lot.
Old 06-09-2007, 09:02 PM
Aquafina's Avatar
Default Re: D16Z6 VTEC Pressure Switch wire color (Aquafina)
I think I have the wrong plug. Referring to Bauleys Mini-Me writeup, the plug he got from a junkyard clip (VTEC pressure plug) is yellow with a blue and a black wire.
Old 06-09-2007, 09:30 PM
Aquafina's Avatar
No yellow plug on the Z6 engine harness.
Tried bypassing the swtich by running a wire from pin C15 (Pres Switch for OBD2) to the VTEC solenoid wire (splied it). CEL 22 didn't go away.
LUiS010606
05-07-2009 12:05 PM
Serdar
09-02-2006 11:35 PM
NobodysHero
07-10-2004 08:10 PM
Who Said
04-04-2003 11:14 PM
Quick Reply: D16Z6 VTEC Pressure Switch wire color
