Greddy Turbo timer counts down when car starts?!
Old 04-27-2007, 04:03 PM
DACteg's Avatar
Default Greddy Turbo timer counts down when car starts?!
So i finally got around to hooking up my greddy turbo timer. i did it from the fuse panel, and im guessing i have a wire switched around. When i turn the car to ACC the timer comes on like it should, but when i go to start my car, the timer starts to do its count down. do i have the wires correct?
Its in a 1990 integra gs.
Red is 12v
Blue is ACC
Green is ON
Old 04-30-2007, 05:23 AM
i my honda
Global Mod
White Smoke's Avatar
Default Re: Greddy Turbo timer counts down when car starts?! (DACteg)
You have the ACC wire (blue) hooked up to a bad sorce. Some sources lose power when you turn to start. You should tap into the sterning column ACC wire.
Old 04-30-2007, 07:23 AM
Supacharge's Avatar
Default Re: Greddy Turbo timer counts down when car starts?! (White Smoke)
have you ever jump started the car while the turbo timer has been hooked up? if so, it may have caused to go crazy.
i had a dead batt. and didnt unhook the timer. now its garbage. after i jumped it off ... for whatever reason now it wont turn the car off. it finishes its count down but the car continues to run.
Old 04-30-2007, 09:32 AM
i my honda
Global Mod
Default Re: Greddy Turbo timer counts down when car starts?! (Supacharge)
Had a similar problem on a friends car before. Unhooked all power to the timer and then hooked it back up. Fixed the problem, hope that helps!
jBj
08-19-2006 06:53 PM
zebt66
02-21-2005 08:21 AM
Quad-Damag
Audio / Security / Video
01-12-2005 04:56 PM
b18tdelsol
06-07-2002 12:47 PM
Ray
07-02-2001 04:01 AM
Quick Reply: Greddy Turbo timer counts down when car starts?!
