Installing lowering springs on civic.
Old 03-15-2007, 06:49 AM
Sontizzle's Avatar
Default Installing lowering springs on civic.
does anyone have a write up or could give me procedure, tools required, etc. on installing some springs on my 1994 civic LX? Thanks!
Old 03-15-2007, 08:33 AM
#1 Super Guy
94eg!'s Avatar
Default Re: Installing lowering springs on civic. (Sontizzle)
Here is a "how-to". I don't have a tool list, but you will need a spring compressor that fits between the coils (hard to find nowadays), a decent jack, some jack-stands, a metric wrench set, a metric socket set, a torque wrench, a breaker bar, and some PB Blaster (penetrating oil). Just make sure you don't torque off the heads of any of the bolts in the rear suspension. If you do you will be hurting. All those bolts get rusted solid very easily and will require some professional attention to remove without breaking. Be careful...
https://honda-tech.com/zerothread?id=1278794
Old 03-15-2007, 03:06 PM
Sontizzle's Avatar
Default Re: Installing lowering springs on civic. (94eg!)
do i need different camber plates or anything else?
Old 03-15-2007, 04:05 PM
#1 Super Guy
94eg!'s Avatar
No you don't. I'm lowered -2.5" in my 94 Civic with no camber adjustment parts, and my camber is just fine for performance driving. (-2.5* front & -1.5* rear). Camber kits cause more problems anyways. As long as you take the car to get a 4-wheel alignment to fix the toe settings after it's lowered, you'll be all set.
Old 03-15-2007, 04:59 PM
Sontizzle's Avatar
what about bushings?
Old 03-15-2007, 05:39 PM
#1 Super Guy
94eg!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sontizzle &raquo;</TD></TR><TR><TD CLASS="quote">what about bushings? </TD></TR></TABLE>
Keep your stock rubber ones. They are better anyways since poly can cause binding and bearings are not meant for the street. Just make sure to follow the instructions I gave you and reset them all after it's lowered. Otherwise the rubber will wear out very quickly...
Old 03-15-2007, 05:44 PM
Sontizzle's Avatar
what do u mean by reset them?! sorry ive never done anything with springs before
Old 12-09-2007, 11:51 PM
ydoubleonie's Avatar
i went to that link. it's crap. i dont know what any of those bolts things look like. i've been searching 2+ hours for a friggin picture DIY for a 96-00 ciivc. i can't believe there is none!
it's not like this car is new to lowering. i guess people just dont feel the need to put up guides cuz it's that easy. but i know many people eff'd up and ended up messing up their lca.... can anyone link me or show me a good diy picture for a civic 96-00... PLEASE!~
Old 12-10-2007, 05:45 AM
EK_B's Avatar
https://honda-tech.com/zerothread?id=1078663
Old 12-10-2007, 08:34 AM
be professional
Targa250R's Avatar
I don't know where you guys have been searching, but this sticky thread has an excellent write-up with lots of detailed pictures showing you exactly what to do:
https://honda-tech.com/zerothread/1106020
Just ignore the parts about modifying the upper mount and bump-stops, because those are specific to installing Koni dampers.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK_B &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=1078663</TD></TR></TABLE>
That's a good one as well. Except the fact that he put coilovers on the stock dampers
Old 12-11-2007, 08:09 AM
EK_B's Avatar
Default Re: Installing lowering springs on civic. (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">
That's a good one as well. Except the fact that he put coilovers on the stock dampers </TD></TR></TABLE>
Yeah, crazy idea. OP, don't do this lol.
Jayhawker
Suspension & Brakes
07-21-2011 08:27 PM
rycrkt
Suspension & Brakes
03-11-2011 03:47 PM
jena_blondie
11-12-2009 08:33 PM
redwards
05-24-2007 11:11 PM
SiRocket02
12-28-2003 09:06 AM
Quick Reply: Installing lowering springs on civic.
