89 Integra suspension
Re: 89 Integra suspension (jblack34)
I used to have an 89 LS and I was always tryin to figure out the same thing lol. Sorry I can't help but http://www.g1teg.org might be able to
Re: 89 Integra suspension (FalkenSiR)
I have an 89. There is a 17 mm adjusting bolt that lets you loosen the tension on the torsion bar. By adjusting it, you can raise it or lower it. The rear uses regular springs, I have tokico shocks and rear springs. One problem though is that the stock torsion bar is soft so when lowering them, the shocks start to bottom out on big bumps. Upgrade motoring sells stiffer torsion bars.
http://www.upgrademotoring.com/
http://www.upgrademotoring.com...0Bars
