Old 11-06-2006, 01:13 PM   #1
Wazup
Wazup's Avatar
Default HOW TO: set readiness monitors for OBD 2
After failing smog for not having the readiness monitors ready, I found this on Wikipedia and thought i would share since it may helpful to some of you.
OBD-II Drive Cycle
(Taken from Understanding OBDII: Past, Present & Future)
The OBD-II drive cycle begins with a cold start (coolant temperature below
122 degrees F and the coolant and air temperature sensors within 11 degrees
of one another).
NOTE: The ignition key must not be on prior to the cold start otherwise the
heated oxygen sensor diagnostic may not run.
1. As soon as the engine starts, idle the engine in drive for two and a half
minutes with the A/C and rear defrost on. OBD-II checks oxygen sensor heater
circuits, air pump and EVAP purge.
2. Turn the A/C and rear defrost off, and accelerate to 55 mph at half
throttle. OBD-II checks for ignition misfire, fuel trim and canister purge.
Hold at a steady state speed of 55 mph for three minutes. OBD-II monitors
EGR, air pump, O2 sensors and canister purge.
3. Decelerate (coast down) to 20 mph without braking or depressing the
clutch. OBD-II checks EGR and purge functions.
4. Accelerate back to 55 to 60 mph at half throttle. OBD-II checks misfire,
fuel trim and purge again.
5. Hold at a steady speed of 55 to 60 mph for five minutes. OBD-II monitors
catalytic converter efficiency, misfire, EGR, fuel trim, oxygen sensors and
purge functions.
6. Decelerate (coast down) to a stop without braking. OBD-II makes a final
check of EGR and canister purge.
I used to be a pretty active member on here, but now I just bump "For Sale" threads for no reason.
Wazup is offline   Reply With Quote
Old 11-06-2006, 01:49 PM   #2
sicones
sicones's Avatar
Default Re: HOW TO: set readiness monitors for OBD 2 (Wazup)
that is a general OBD2 procedure, it varies for most makes and models
sicones is offline   Reply With Quote
Old 11-06-2006, 01:54 PM   #3
Wazup
Wazup's Avatar
Default Re: HOW TO: set readiness monitors for OBD 2 (sicones)
yeah thats what i figured.. but i thought i might at least alert people (esp. califonia people) to what smog techs look for when testing.. Basically, just be sure your readiness codes are ready... OBD 2 is such a pain
2006, accord, civic, cycle, drive, driving, honda, monitors, obd, obd2, obdii, procedure, readiness, rsx, smog
