How much air pressure do i put in my tires???????????
Old 09-07-2006, 08:00 PM
integracura's Avatar
Default How much air pressure do i put in my tires???????????
I have 205/45/17's, my car says i need 29 psi in front & rear for LS.
Old 09-07-2006, 08:12 PM
SE3Pimp's Avatar
Default Re: How much air pressure do i put in my tires??????????? (integracura)
um.. on the side wall of the tires... it tells u the psi max... put air amount near that...
Old 09-07-2006, 08:21 PM
Daisy... Daisy...
Dogginator's Avatar
Default Re: How much air pressure do i put in my tires??????????? (EndlessDc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EndlessDc2 &raquo;</TD></TR><TR><TD CLASS="quote">um.. on the side wall of the tires... it tells u the psi max... put air amount near that...</TD></TR></TABLE>
Start with the 29 psig. Tire pressure needs to be tuned slightly for both your suspension and tires.
Old 09-07-2006, 08:39 PM
yea cuz i have adjustable coilovers and i actually have 205/40/17's. So i should put 29 psi.
Old 09-07-2006, 08:43 PM
90b20vteckidd's Avatar
Default Re: (integracura)
35 psi dude
Old 09-07-2006, 08:44 PM
Daisy... Daisy...
Dogginator's Avatar
My guess is that you will settle in the low 30 psig range. You need to tune both the ride and the handling to your taste.
Old 09-08-2006, 04:02 AM
Snafubmx234's Avatar
Does anybody have a writeup on this?
Old 09-08-2006, 06:31 AM
H-T Order of Merit
nsxtasy's Avatar
Default Re: (Snafubmx234)
DON'T use the max inflation on the sidewall as the pressure to set. That's like saying that your speedometer goes up to 140 so you should be driving around at 140 mph all the time. (Not that that wouldn't be fun. )
In general, it's a good idea to set the tire pressure recommended by the car's manufacturer as a starting point, and then adjust from there based on personal preference, treadwear patterns, etc.
The recommended pressure for the non-VTEC Integras is 29 all around, I believe. The recommended pressure for the VTEC Integras (GS-R and Type R) is 35 front, 33 rear. I believe this was done because 35F/33R gives better handling, while 29 all around provides a more comfortable ride. For a starting point, I would choose from these based on your own personal preference for performance vs ride comfort, or you can set it to something in between for a blend of both. Then adjust it in 2 psi increments based on your experience.
ammob16
11-11-2005 11:10 AM
RynoDyno312
09-09-2005 01:04 PM
CereaLand
09-04-2003 05:37 PM
CereaLand
09-04-2003 02:22 PM
94integrablur
04-18-2002 09:36 PM
Quick Reply: How much air pressure do i put in my tires???????????
