> Honda CRX / EF Civic (1988-1991)
Old 08-30-2006, 11:06 AM   #1
4gencivicef9
4gencivicef9's Avatar
Default Car bogs when you hit the gas, and when driving if I floor it bogs like I am down shifting..?
anyone had this I just did a b16a swap into a 89 dx 1.5 I was thinking maybe it might be a lean condition and I am going to swap out the fuel pump also I am going to change ecu cause I have a pr3 ecu that is automatic?
Just figured I post up and see if anyone has had this prob..?
OUT OF THE GAME!
4gencivicef9 is offline   Reply With Quote
Old 08-30-2006, 11:49 AM   #2
Maldito X
Maldito X's Avatar
Default Re: Car bogs when you hit the gas, and when driving if I floor it bogs like I am down shifting..? (4
I have the same problem, but its on my d16a6, and I'm pretty sure its my ignitor in my distributor. Other problems could be a filter and or dirty injectors. Though I'm almost certain its ignitor that's bad.
Autozone can run diagnostic check on your ignitor and tell you if its bad, I think. But I am not certain, since its a pr3, and idk what dizzy you are running. I don't know if that would be a problem.
Snap Your Fingers, Snap Your Neck
Whose Fist Is This Anyway?
'91 CRX <FONT COLOR="red">Si</FONT>
'98 22B <FONT COLOR="pink">STi</FONT>
'70 Camaro <FONT COLOR="red">z</FONT>28
Maldito X is offline   Reply With Quote
Old 08-30-2006, 12:18 PM   #3
4gencivicef9
yea I am obd0 I think it is td-22 or td-44 it's obd0, but thanks I am going to try to take to autoparts place and get it tested I dont think they do that around my way though..?
OUT OF THE GAME!
Old 08-30-2006, 12:22 PM   #4
4gencivicef9
I cleaned out my injectors and put new seals and still the same they are working though is there away to test them..? or tell? I think it is between the fpump and ecu though..
OUT OF THE GAME!
Old 08-30-2006, 01:09 PM   #5
Maldito X
Maldito X's Avatar
Yeah, I suspect its a problem with your dizzy,like the ignitor, I don't know what replacement there is for an obd 0 dizzy on ur b16, I'm not sure if you can mix and match, but why not go and find an obd0 ignitor off a b18 integra. Checker, kragen, autozone might run a check on ur ignitor, autozone offered to diagnose mine before buying. Is your tach needle bouncing around?
The Punk has me set on 10 posts a day limit, so if I have more to say, I will edit this post. Therefore read back on here to see if I respond, instead of checking for a new post from me.
Old 08-30-2006, 02:30 PM   #6
eudm_eg8
eudm_eg8's Avatar
i had the same problem on my d15b2 - when i pressed on gas pedal it bogged, if i floored it, it bogged like crazy.then one day my car wouldn't start up - there was no spark.my mechanic changed the ignition coil and now it works like new.
eudm_eg8 is offline   Reply With Quote
Old 08-30-2006, 03:55 PM   #7
saikouEF8
saikouEF8's Avatar
check your thermostat ground wire. if not that then check coil and igniter
saikouEF8 is offline   Reply With Quote
Old 08-30-2006, 05:47 PM   #8
CASTUDILLO01
CASTUDILLO01's Avatar
MAKE SURE YOU SWAP THE YELLOW/WHITE AND GREEN/WHITE WIRE ON THE TPS SENSOR THEY READ BACKWARDS IN A DUAL POINT SYSTEM THEN ON A MILTIPORT. FOUND THAT TO BE VERY COMMON ON SWAPS PEOPLE DID AND FORGOT TO SWAP THOSE WIRES AROUND. ALSO USE A JUMPER HARNESS ON THE DISTRIBUTOR BETTER THEN SWAPPING WIRES AROUND AND HAVE TO RUN WIRES TO THE ECU.
CASTUDILLO01 is offline   Reply With Quote
Old 08-30-2006, 06:35 PM   #9
4gencivicef9
I am going to check the ignition coil to double check..
OUT OF THE GAME!
Old 08-30-2006, 06:37 PM   #10
4gencivicef9
? I dont understand the car will bog if the tps is backwards, yel/white , gre/white. on the ecu?
OUT OF THE GAME!
Old 08-30-2006, 06:50 PM   #11
Mr. Giggles
Mr. Giggles's Avatar
a wire on my map sensor was disconnected.. backfired and bogged like a bitch.
$$$$Use KIV742 for 5% off your entire order at www.trueprotein.com 10% if you order 16 lbs or more!!!!$$$$
Berlina MOB #017
Mr. Giggles is offline   Reply With Quote
Old 08-30-2006, 08:05 PM   #12
mahatma
mahatma's Avatar
cam timing a tooth or 2 off?
FS: 2 B-series turbo manifolds.... 1 is brand new Ebay special log-style, 1 is custom log-style, thick flanges sturdy as fawk! $50 each
EF Sedan Squad #26
mahatma is offline   Reply With Quote
Old 08-30-2006, 08:09 PM   #13
SVOboy
SVOboy's Avatar
Send a message via AIM to SVOboy
He was saying that if you didn't switch the tps wires when you did the MPFI wiring it will cause such things, I'm with him for now.
www.crxMPG.com &lt;-- MPG the CRX way, http://images.honda-tech.com/set1/smile/emwink.gif
http://www.ecomodder.com &lt;-- Trick out your car for fuel economy!
SVOboy is offline   Reply With Quote
1989, 1995, 89, bogging, bogs, camaro, civic, d15b2, driving, floor, floored, flor, gas, integra, pressed, when
