P0325
Old 06-15-2006, 08:16 AM
Excelerate's Avatar
Default P0325
Is this CEL related to detecting knock or is that hte knock sensor is defective or the wiring is messed up?
Old 06-15-2006, 08:20 AM
Meat Robot Invisible
khunt0012's Avatar
Default Re: P0325 (Excelerate)
P0325 Knock Sensor Circuit Malfunction
I imagine that means something is messed in the wiring not the sensor itself, but I couldn't tell you with 100% certainty.
Old 06-15-2006, 08:29 AM
In a Junkyard near you.
Ross 2.0's Avatar
First of all you need to tell us what year and model of car this is
Old 06-15-2006, 08:34 AM
khunt0012's Avatar
Default Re: (MooGoCow3)
I just assumed the 1999 Accord in his sig.
Old 06-15-2006, 08:50 AM
Ross 2.0's Avatar
Yea I would assume that too I just want to be sure. I messed myself up a few good times on an assumption.
Old 06-15-2006, 09:05 AM
khunt0012's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MooGoCow3 &raquo;</TD></TR><TR><TD CLASS="quote">Yea I would assume that too I just want to be sure. I messed myself up a few good times on an assumption. </TD></TR></TABLE>
That would make 2 of us.
Old 06-15-2006, 12:19 PM
Excelerate's Avatar
Default Re: (khunt0012)
1999 Accord LX 2.3L
Old 06-15-2006, 12:32 PM
khunt0012's Avatar
Default Re: (Excelerate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Excelerate &raquo;</TD></TR><TR><TD CLASS="quote">1999 Accord LX 2.3L </TD></TR></TABLE>
My first response is correct then. Refer to that.
Old 06-16-2006, 08:41 AM
JimBlake's Avatar
Default Re: P0325 (khunt0012)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by khunt0012 &raquo;</TD></TR><TR><TD CLASS="quote">P0325 Knock Sensor Circuit Malfunction
I imagine that means something is messed in the wiring not the sensor itself, but I couldn't tell you with 100% certainty.</TD></TR></TABLE>I think it could also be the sensor itself is bad. But I don't think that code is related to the system detecting knock.
Old 06-16-2006, 10:31 AM
khunt0012's Avatar
Default Re: P0325 (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">I think it could also be the sensor itself is bad. But I don't think that code is related to the system detecting knock.</TD></TR></TABLE>
That's correct. The CEL is for a malfuntion in the knock sensor/wiring, not detecting knock itself.
Old 06-16-2006, 11:10 AM
Ross 2.0's Avatar
First step
DTC P0325: KS Circuit Malfunction
Reset the ECM/PCM.
Start the engine. Hold the engine at 3,000 rpm with no load (in Park or neutral) until the radiator fan comes on, then let it idle.
Hold the engine at 3,000-4,000 rpm for at least 60 seconds.
Is DTC P0325 indicated? YES - Go to step 4.
NO - Intermittent failure, system is OK at this time. Check for poor connections or loose wires at the knock sensor and at the ECM/PCM.
Let us know what you find out
Old 07-21-2006, 03:52 PM
Excelerate's Avatar
I tried what you said. I let the fan cycle on and then held the revs at about 3500 for about 60 seconds or so. No CEL. What next? I've checked the knock sensor and the plug and they all look good. I guess I have to look at the ECU next. What about voltage readings?
jnwalker
05-02-2014 12:17 PM
tomtom211
02-09-2012 03:36 PM
Playa_FL
03-22-2007 08:25 AM
Grnade
05-02-2005 08:45 PM
xwade01
03-17-2005 09:53 AM
Quick Reply: P0325
