My car won't start when it's HOT outside!!??
Old 05-28-2006, 11:46 AM
TealCivic93's Avatar
Default My car won't start when it's HOT outside!!??
I left my house this morning when it was cool outside. Didn't have a problem. This afternoon though when the temperature was at it's peak the car was turning but not starting. Last summer it happened sometimes but I would wait a few minutes and it would start after. Would I need a tune up? Thanks
Old 05-28-2006, 01:00 PM
Deo
Deo's Avatar
Default Re: My car won't start when it's HOT outside!!?? (TealCivic93)
Most likely the Main Relay, easy fix. Search it for a guide.
Old 05-28-2006, 01:05 PM
I tell doctors what to do
ILcrxsi1's Avatar
Default Re: My car won't start when it's HOT outside!!?? (Deo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deo &raquo;</TD></TR><TR><TD CLASS="quote">Most likely the Main Relay, easy fix. Search it for a guide.</TD></TR></TABLE>
Old 05-28-2006, 01:18 PM
thanks. I will search for it. I was told the same thing on a local forum.
Thanks again.
JF
Old 05-28-2006, 09:40 PM
nostreble's Avatar
Default Re: (TealCivic93)
if its the main relay, just let some air inside the car too cool down.
Old 05-29-2006, 05:49 AM
crx_88_si's Avatar
Default Re: (nostreble)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nostreble &raquo;</TD></TR><TR><TD CLASS="quote">if its the main relay, just let some air inside the car too cool down.</TD></TR></TABLE>
only works *sometimes*. Mine had the same problem.
I found if i sat there cycling the key to on / off / on / off eventually it would work, but then i had to change my ign switch. so, replace the relay, lol.
Old 05-29-2006, 06:28 AM
'90crxSI's Avatar
It is definetly the main relay. Detailed problems and a fix can be found here: http://www.tegger.com/hondafaq/faq.html#startrun
Soldering is very easy on this! I've done mine, and no longer have problems! Give it a shot!!!
90_civic_Si
12-07-2006 11:56 AM
89sicivic
21
06-21-2006 02:00 PM
DXDOHCVTEC
13
04-20-2005 04:57 AM
teler86
01-14-2005 10:57 AM
DAMCOOLDAV
08-28-2004 09:19 AM
Quick Reply: My car won't start when it's HOT outside!!??
