Does My 94 Accord Have 2 Thermostats???
Old 05-21-2006, 06:35 PM
J-Ra's Avatar
Default Does My 94 Accord Have 2 Thermostats???
Aight my car been overheating bad enough to where I'm driving the car for about 10-20 min and the temperature goes all the way up, sometimes past the redline. Now today I bought a new thermostat and gasket for it and replaced it but when i took out the old one, it was perfectly fine because I had the work done about 6 months ago. so the new one is in and I still have the same overheating problem. I noticed that on the top of the radiator where the cap is, there is another hose that connects to the engine which looks like another housing to a thermostat. is that a thermostat or is it something else?? I'm asking now because tomorrow I'm gonna take it off and see whats in there and take the other thermostat and put it in there. So is that another thermostat?? And if not what else could be the problem?? I'm already on my 3rd water pump and timing belt which was done 6 months ago. Thanks in advance
Old 05-21-2006, 06:49 PM
Global Moderator
tech8's Avatar
Default Re: Does My 94 Accord Have 2 Thermostats??? (J-Ra)
Your car only has one thermostat, it is located in the thermostat housing connected to the lower radiator hose.
Edit: Correction, thermostat housing connected to lower radiator hose.
Modified by tech8 at 9:06 PM 5/21/2006
Old 05-21-2006, 07:30 PM
J-Ra's Avatar
Default Re: Does My 94 Accord Have 2 Thermostats??? (tech8)
I got 2 then cause the thermostat that I changed was behind the engine on the passenger side where the bottom hose thats connected to the radiator goes to the housing to the thermostat. So I guess ill be messing with the top one tomorrow
Old 05-21-2006, 07:40 PM
Global Moderator
tech8's Avatar
Edit: Correction.
Modified by tech8 at 9:07 PM 5/21/2006
Old 05-21-2006, 07:50 PM
Global Moderator
tech8's Avatar
If you replaced the thermostat, then that is the only thermostat.
Here is a link regarding cooling problems:
http://www.tegger.com/hondafaq/faq.html#engines
Old 05-21-2006, 08:45 PM
J-Ra's Avatar
Default Re: (tech8)
ight thanks man definatly appreciate it
Old 05-25-2006, 05:00 PM
Jmumblez2001's Avatar
there is only one thernostat in your accord cause i have the same year you're talking about. I wouldn't bother taking that uper hose off unless ya really had too.
Old 05-25-2006, 05:03 PM
NAiL05's Avatar
Default Re: Does My 94 Accord Have 2 Thermostats??? (Jmumblez2001)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jmumblez2001 &raquo;</TD></TR><TR><TD CLASS="quote">there is only one thernostat in your accord cause i have the same year you're talking about. I wouldn't bother taking that uper hose off unless ya really had too.</TD></TR></TABLE>
Take off the upper hose??? Anyway as mentioned follow the lower radiator hose and it will take you to the thermostat housing in the back of the engine bay. The front DOES NOT have a thermostat that tricked me the first time I got my 90 Accord. It just looks like a housing and your only supposed to have one thermostat as mentioned already.
larbabe
02-15-2014 10:59 AM
SW20FL
07-28-2011 07:41 AM
BIGPAPAWACK
12-13-2008 12:16 AM
Quick Reply: Does My 94 Accord Have 2 Thermostats???
