Rust repair quarter panels
Old 05-10-2006, 04:36 AM
  #26
boonacka's Avatar
Default Re: Rust repair quarter panels (88 rex)
let me know when you get them in. I definately need a set.
Old 05-10-2006, 06:37 PM
  #27
b16civster's Avatar
Default Re: Rust repair quarter panels (boonacka)
me 2 i need a set for a 88 crx
Old 05-10-2006, 09:04 PM
  #28
Duncan90si's Avatar
Default Re: Rust repair quarter panels (b16crexster)
this site has cheap full quarters (not for the crx though ) and patch panels. I deal with them almost daily at my shop. Quality is pretty good for being aftermarket panels. http://www.pacollision.com/cgi...=2908
my $.02.
Old 05-10-2006, 09:39 PM
  #29
Cuda70's Avatar
Default Re: Rust repair quarter panels (Duncan90si)
When you are done welding, hit the back side of that panel with some good epoxy primer and you should not have rust problems.
Also, it is extremely important to figure out where you are leaking water and repair that as well. Most of the time, these CRX's leak from worn out trunk gaskets/weather stripping.
Old 05-11-2006, 02:18 AM
  #30
Deviation's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Duncan90si &raquo;</TD></TR><TR><TD CLASS="quote">this site has cheap full quarters (not for the crx though ) and patch panels. I deal with them almost daily at my shop. Quality is pretty good for being aftermarket panels. http://www.pacollision.com/cgi...=2908
my $.02.</TD></TR></TABLE>
$40 for the same panels. Not bad.
Old 05-11-2006, 05:29 AM
  #31
90crxlst's Avatar
i have used these panels on a crx. the wheel arches are the same. u just need to just the panel off where the molding is because the hatches are thicker.
Old 05-11-2006, 06:38 AM
  #32
blumpfish's Avatar
Default Re: Rust repair quarter panels (90crxlst)
even those wouldnt work on mine, it looks like someone hit the rear qp and its dented in , the trim fell off and its all rusted past where those new ones would fit in
Old 05-11-2006, 11:36 AM
  #33
Duncan90si's Avatar
They do make a weld thru primer. Prime the panel before placing it on the car. This primer allows a proper weld even though its not bare metal.
Old 05-11-2006, 12:23 PM
  #34
mntuner2's Avatar
Default Re: (Duncan90si)
Just ordered a left rear quarter from pensylvania auto parts. I talked to Kelly and she seems to know all. I can't wait to fix the rust and paint my EF a different color :D
Modified by mntuner2 at 11:04 PM 5/16/2006
Old 09-13-2006, 10:20 PM
  #35
zerons hell's Avatar
Default Re: Rust repair quarter panels (Deviation)
definitely need a set of those panels. Tried finding it on the site, cant find it. Anyone got the part number for these?
mini-meEj1
Paint and Body
11-12-2007 08:54 AM
johnkilo3
Welding / Fabrication
07-14-2007 02:31 PM
CivicSiDriver02
03-06-2006 05:58 PM
tzenisj
07-21-2004 09:37 PM
Quik89Si
07-05-2002 08:56 AM
Quick Reply: Rust repair quarter panels
