Average cost to replace CV Joint?
Old 04-23-2006, 07:37 AM
CRISIS's Avatar
Default Average cost to replace CV Joint?
Is it really expensive? I was just curious because all the shops in my neighborhood are closed. It's for an eg sedan. Thanks.
Old 04-23-2006, 07:42 AM
Soccerking3000's Avatar
Default Re: Average cost to replace CV Joint? (CRISIS)
uhh you would just replace the axle they are like 40 bucks fron honda
Old 04-23-2006, 07:59 AM
CRISIS's Avatar
Default Re: Average cost to replace CV Joint? (Soccerking3000)
Isn't a cv joint a piece on it's own? Also would it make a clicking noise when i go in a straight line? Or would that be the axle? I'm so confused.
Old 04-23-2006, 08:06 AM
the cv joint is part of the axle, it allows the axle to bend with the suspension, and yea it will make that clicking noise, just replace the axle, they are one in the same essentially. If you replace the axle the cv joint is replaced as well because it is part of the axle...
Old 04-23-2006, 08:17 AM
CRISIS's Avatar
Then what is the piece that is behind the axle? More towards the back of the car. It has a tie rod at the end of it. The boot is busted and it started making noise. Covered it with lube and it went away. But now the sound is back. :-( Sorry i don't have any pics.
Old 04-23-2006, 08:21 AM
JeBuSrIcE's Avatar
thats the steering rack...u can change the boots out and put lube back in.....its not that expensive
Old 04-23-2006, 08:24 AM
CRISIS's Avatar
Default Re: Average cost to replace CV Joint? (JeBuSrIcE)
But that wouldn't cause the clicking would it. And what will happen if my axles snap?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JeBuSrIcE &raquo;</TD></TR><TR><TD CLASS="quote">thats the steering rack...u can change the boots out and put lube back in.....its not that expensive</TD></TR></TABLE>
i've seen this done, but i would still just replace the axle, you have to pretty much take the old one out either way so why put one back in that might still be damaged
Old 04-23-2006, 08:52 AM
Hondaciv95VX's Avatar
REPLACE THE AXLE! EASIER, and you will get a warranty on the axle, which includes the boot.
Warranty = owned.
tundra2000
04-08-2011 11:54 AM
grkblood13
Transmission & Drivetrain
04-02-2009 05:09 PM
TheTealHatch
06-28-2007 09:55 PM
Rocks
06-28-2004 11:06 AM
penney
04-16-2004 06:58 PM
Quick Reply: Average cost to replace CV Joint?
