Civic GL dualcarb gauge cluster swap problem
Old 04-17-2020, 02:07 PM
MasterMegatron's Avatar
Default Civic GL dualcarb gauge cluster swap problem
Hello. I have a Civic GL 89 with a dualcarb and I have problems with replacing the dashboard. I bought a gauge cluster from the injection restyle civic. I know that you need to rewire cluster for injector dash, but the wires from my Civic do not match the diagram I found on this site (https://honda-tech.com/forums/honda-...hatch-2821961/) They have a different arrangement of wires and maybe colors.
Does anyone have a photo or diagram where I can find out how to re-strip this dash? (My original GL dash and wires on foto.) Sorry for bad english and thanks in advance.
[img]data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAABQAAAAUCAQAAAA ngNWGAAAA/0lEQVR4AYXNMSiEcRyA4cfmGHQbCZIipkuxnJgMStlMNmeyD2d wmc8+sZgxYJd9ErIZFHUyYYD7fkr6l4/rnvmtl7+KitrqV/fq2Y5eLY3Z9S48eRLe7BmVZ9qhTLhQ0algzZWQOVKSsCF8OjAn wbxDTWFDUhPK/jMr1H6HE/IqRky2DyvCefuwItwZzodVoYRiLqMkVCXrwpJ9twZ+sgfDYEFY l8wIWxZ9uFf7zkallxlJh4YrLGsKjZRx7VGHhLqwgFUN45DGdb 8MeXGpgB4ABZdeDcpZEY51A+hyLKz4S1W4MQWm3AibWtgWmk6d yISa1pSdyWTOlLXVp0+eL9D/ZPfBTNanAAAAAElFTkSuQmCC[/img]
Old 04-25-2020, 01:39 AM
79cord's Avatar
Default Re: Civic GL dualcarb gauge cluster swap problem
I swapped fitted an injected D16z6 drivetrain & wiring from a '91 Japan built Concerto into my 1.5l dual carb '91 Civic Hatch so had to identify both the sets of wires into the Civic's original cluster, so here's what I wrote down if deciphering it doesn't drive you crazy.
Probably not very useful though since I know some wires were changed for the facelift instrument cluster (late '89)..
So avoiding other tasks I thought I'd better sort out Concerto wiring fitted to '91 Civic to refit its proper cluster
Not sure that info will be of much use to others given rarity of Concerto here & significant differences between Japanese & British built cars....
'91 Civic & '91 Concerto gauges
'91 ED Civic GL (top) & '91 Concerto Clusters
So mapping their printed circuits to show Plug contact -> funtion/light numbered L-R
'91 Civic
1 - Earth-
2 - Speedo
3 -
4 - Boot Open
5 - **making this low Fuel**
6 - Fuel Gauge
7 - Power supply+
8 - Right indicator
9 - Left indicator
10 - High beam
11 - Temp Gauge
12 - Cluster lighting (red-black)
13 - Cluster lighting (red)
14 -
15 - Brake
16 - Oil
17 - **Making this Check Engine)
18 - Battery (Black-Yellow)
19 - Battery (White-Blue)
20 - Tachometer
'91 Concerto
1 - Brake
2 - Boot Open
3 -
4 - Low Fuel
5 - Fuel Gauge
6 - Speedo Gauge
7 - Earth
8 - Right indicator
9 - High beam
10 - Left indicator
11 - Tachometer
12 - Cluster lighting (red)
13 - Cluster lighting (red-black)
14 - Temp Gauge
15 - Check Engine
16 -
17 - Battery (Black-Yellow)
18 - Battery (White-Blue)
19 - Oil
20 - Power supply+
Plugs match but every wire moved to match cluster
Concerto() moves to Civic () - Concerto wire colour
(1)->(15) - Green,Red,2spots
(2)->(4) - Green,Yellow
(3)
(4)->(5) - Green,Red
(5)->(6) - Yellow,White,2spots
(6)->(2) - Yellow,Red
(7)->(1) - Black
(8)->(8) - Green,Yellow,1spot
(9)->(10) - Red,Blue,1spot
(10)->(9) - Green,Blue,1spot
(11)->(20) - Blue,2spots
(12)->(12) - Red,Black,2spots
(13)->(13) - Red,1spot
(14)->(11) - Yellow,Green,2spots
(15)->(17) - Green,Orange,1spot
(16)
(17)->(18) - Black,Yellow,1spot
(18)->(19) - White,Blue,1spot
(19)->(16) - Yellow,Red,1spot
(20)->(7) - Yellow,1spot
I had to open up two lenses in the Civic warning light cluster for new Check Engine & Low Fuel lights in blanked unused holes.
JohnnyTryHard
09-02-2012 08:50 PM
361 accord
02-02-2009 06:14 PM
snouka
03-16-2005 04:11 AM
SnowSurfer
06-20-2004 08:08 AM
dingusjt
05-10-2003 09:34 AM
Quick Reply: Civic GL dualcarb gauge cluster swap problem
