car starts then shuts off 5-10 minutes later??? what is the problem???
Old 08-30-2005, 08:11 AM
92integraVTECgsr's Avatar
Default car starts then shuts off 5-10 minutes later??? what is the problem???
The car will start and idle smoothly for 5-10 minutes before it shuts off. After about 5-10 minutes the car can be started again and it will run for another 5-10 minutes or so before it shuts off again. During the 5-10 minutes the car is running, it drives fine and seems to have no other problems (other than the brakes will need to be replaced and possibly the tires). In an attempt to solve the electrical problem, the car has new: distributor, fuel pump, fuel filter, and ignition switch.
DOES ANYONE KNOW WHAT THE PROBLEM COULD BE?????
Old 08-30-2005, 08:15 AM
Will you make something up for me please?
shamoo's Avatar
Default Re: car starts then shuts off 5-10 minutes later??? what is the problem??? (92integraVTECgsr)
What happens when the car dies? Describe exactly what happens. When you try to start it again right after it does (before 5-10 minutes), what happens? Does it crank? Fuel? Spark?
Old 08-30-2005, 08:24 AM
chahsiubow's Avatar
sounds like the alternator or battery crapping out
Old 08-30-2005, 08:43 AM
Sack Master's Avatar
Default Re: (chahsiubow)
When you replaced the distributor, did you get a new coil as well? Check to see what the problem is. Is it fuel or is it spark?
Old 08-30-2005, 10:36 AM
B18C_DD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chahsiubow &raquo;</TD></TR><TR><TD CLASS="quote">sounds like the alternator or battery crapping out</TD></TR></TABLE>
Couldn't be the battery because the car starts fine he said. But maybe the alternator.
Definetly an odd situation.
Good luck
Old 08-30-2005, 10:39 AM
T
I had that same problem with a hatch. Would drive and then just suddenly turn off. It's probably your alternator. Thats what it was for me, once replaced ran great.
Bloody Hatch
65
06-08-2012 06:12 AM
VSG
12-17-2008 12:42 PM
SOHC_civic_si
17
07-29-2008 06:17 PM
Vitesse
08-26-2006 01:38 PM
SoCal ITR
05-06-2004 10:27 PM
Quick Reply: car starts then shuts off 5-10 minutes later??? what is the problem???
