| Welcome to Honda-Tech! | ||
#1 |
what is the stock tire pressure on the 13 inch steelies?
92 Dx Hatch y7 totaled 05 gsxr 750 | 97 Cosmos Black 4Door M3 | 96 Cx Hatch B18B 90 CRX hf ZC -sold- | 93 Cx Hatch B16 -sold- | 03 R1 -sold- 93 Ex coupe -sold- | 91 CRX dx ZC -sold- 97 240SX -sold- | 89 CRX Si -sold- |
#2 |
hey, mine said 35 psi max, but i did this and they still seem to buldge,
it should say on the side of your tire too in parenthsis? ( max psi blah blah )
Current Rides- 91 Dx Crx (Build Thread) http://www.honda-tech.com/zerothread/2337585 93 Dx Hatch |
#3 |
Mine say 45 max..
it will say it on your tire....just look its not by size, and not all tires are the same
94 Civic Coupe - [I]SOLD[/I] 92 Civic Hatch - [I]SOLD[/I] 98 Audi A4 - [B]FOR TRADE[/B] Trade me a clean Honda for my Audi A4 [img]http://images.honda-tech.com/set1/smile/emthup.gif[/img] [url="http://hondamarketplace.com/zerothread?id=1715180"]http://hondamarketplace.com/zerothread?id=1715180[/url] |
#4 |
On the inside of the glovebox is a sticker that tells the cold tire pressure. DO NOT USE THE MAX PRESSURE RATING ON THE SIDE OF THE TIRE. What year and model is it?
If It Ain't Broke, Don't Fix It! '87 CRX Rest in Peace (Head on crash) '88 Civic HB DX/ZC Rest In Peace (Hit from behind) '89 Crx SI/ZC Rest In Peace (Gave it to my son and he killed it) '93 SI HB bone stock for now |
#5 |
why does everyone think that you go by the tire, you go by the manufacturerers spec's which are in the door pillar on the drivers side or in the glovebox on some models. dont EVER go by they max psi on the tire because thats the maximum it can withstand for a period of time before it will start to **** the tire up internally.
Shitty Blue 2006 Elantra (Current, damn ex-wife) : Diamond White Pearl 2001 IS300 (Sold) : Sebring Silver 2002 AP1 (TRADED) : Milano Red 2000 EM1 (TRADED) : Milano Red 1993 EJ1 (SOLD) : White 1994 Civic 4Dr (TOTALED) |
#6 |
look in ur glove box on left side
www.eastcoastchopstix.com, Western North Carolina community, Check us out! |
#7 |
There is different profile of tires, not ALL 13" steelie tires will require the same PSI rating.
When i purchased my 92 Civic Hatch it had tires that had a max psi of 35. Now i replaced the tires with tires that require a max PSI of 44. I never have them inflated to the max psi, 5 under usually. Good luck.
#8 | |
Do not EVER go by what it says on the tire. There should be a sticker in the drivers door frame that will say the manufacturer recomended tire pressure. The number on the tire is the max psi that the tire can hold.
|D|R|U|G|S| My Anti-You 1995 C5 Powered Ex sedan (Stolen) Thieves suck ****. 2006 Lincoln Mark LT 1987 Mazada RX-7 (4-rotor build in progress) 1997 Accord Special Edition 1997 Civic Cx (Sold) 1981 BMW 320i (Sold http://images.honda-tech.com/set1/smile/emsad.gif ) <FONT COLOR="blue">Member #C of ES</FONT> THE CONE Official Fan Club Lubrication Expert Member #13 |
#9 | |
#10 |
The profile of the tire has little or nothing to do with proper inflation pressure. The manufacturer has tested the vehilcle for optimum performance with stock setup. if you are racing then sometimes it is best to start at a slightly lower pressure so that as the tire (and the air in it) heat up the proper pressure is mantained. No one driving on the street keeps enough heat in the tires to warrant such action. If you have quetsions regarding potential deviatrion from stock pressures contact the tire manufacterer or someone like Tirerack for advise concerning pressure. NEVER USE THE MAX INFLATION LISTED ON THE SIDEWALL OF THE TIRE.
#11 | |
Nobody likes you.
#12 | |
#13 | |
1991 Acura IntegraMy Garage |
'89 Civic Sedan LX / '91 DA9 / '92 DB1 |
#14 |
ya knwo how im feelin now, screw it, no one bothers to listen on this site to people who know what theyre talking about and just chime in with what their cousin bubba or whoever told them. f that. sick of trying to help people out and have other people chime in with **** they dont know about and jsut tellin how they do **** which is wrong. and ive NEVER once in my LIFE heard of anythign but a large truck runnin over 35
#15 |
32 cold, plus or minus 5 is safe.
and yes, the max psi on the tire isnt what you should be using. since when is the "maximum" ever the most reliable? |
#16 | |
#17 |
somehow every question on h-t turns into a flame or debate. simple answers, its not that hard, people!
#18 |
i have 13's and i fill them with 37psi.
#19 | |
#20 |
I am not exactly sure what the consensus was but I have a similar question.
My sticker on the door says 30psi or whatever but it says the recommended tire size is 14". I have dropped to 13" and kept an almost identical overall diameter. Should i still run the exact same pressure? Does the vehicle recommended inflation hold true for any tire size or just the recommended tire size stated on the sticker? |
#21 |
yes i would if i were you, after a few thousand miles or your next oil change get the tread depth measured and if theyre wearing a lot more on the outside and inside edge then put a llittle more in but shouldnt be much more than a couple 2 or 3 psi.
#22 |
What I have found is the best way to set the optimum tire pressure, regardless of the width/profile of the tire Start with them set to the factory specs. Then bump it up 2 psi and then two psi below the factory recommendation. Which ever one makes the car handle/ride like you want it too then leave it there. Be sure to monitor tire wear to be sure you are not sacrificing tread wear for "feel". If the presssure is set to high it can actually reduce the tire footprint. If it is too low the tire will overheat damaging the sidewall and reducing the effective life of the tire. DO NOT JUST READ THE SIDE OF THE TIRE FOR SETTING THE TIRE PRESSURE! THAT IS THE MAXIMUM ALLOWED NOT WHAT IS BEST FOR YOUR PARTICULAR CAR. SEE Above!
#23 | ||
i take back part of what i said. minimum 28 psi, maximum 38 or so. tpr's method works fairly well for determing whats good, but the biggest thing is checking for even wear. this is, of course, assuming you have 0* of camber, and a proper alignment. Quote:
#24 |
sweeeeeeet
thankyou all |
| Tags |
| 13, 87, 92, civic, crx, honda, inch, optimal, pressure, psi, size, sizes, steelies, stock, tire, tyre |
