Changing Transmission Fluid
Old 02-26-2007, 10:59 AM
  #26
JamesLock's Avatar
Default Re: (cambopheonix56)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cambopheonix56 &raquo;</TD></TR><TR><TD CLASS="quote">
i agree. don't flush the trans.</TD></TR></TABLE>
Old 02-26-2007, 11:02 AM
  #27
importfanatic17's Avatar
Default Re: (sony224422)
My bad, I thought the drain and fill were both on the tranny. Is it different for an auto?
Old 02-26-2007, 02:21 PM
  #28
Mitsu's Avatar
Default Re: (importfanatic17)
it's a 95 accord, I thought there was an accessable drain plug?
Old 02-26-2007, 03:23 PM
  #29
pos_cd5's Avatar
Default Re: (Mitsu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mitsu &raquo;</TD></TR><TR><TD CLASS="quote">it's a 95 accord, I thought there was an accessable drain plug?</TD></TR></TABLE>
there is, its on the passenger side and has a slot to fit a 3/8 drive ratchet into to loosen it.
Old 02-27-2007, 05:54 PM
  #30
professorman's Avatar
Default Re: (pos_cd5)
I always hear mechanics that say that if a transmission is going, if you put in fresh tranny fluid, it goes faster than with the old one in it. With that said, the drain and refill might be the way to go. The drain and refill is what the service manual from honda recommends.
Old 02-27-2007, 06:18 PM
  #31
Mitsu's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pos_cd5 &raquo;</TD></TR><TR><TD CLASS="quote">
there is, its on the passenger side and has a slot to fit a 3/8 drive ratchet into to loosen it.</TD></TR></TABLE>
ok thats what i thought, thanks.
Old 07-25-2008, 11:52 PM
  #32
xlilsharkyx's Avatar
Default Re: (Mitsu)
for a 99 v6 accord is the drain plug a 3/8 drive too or something different? and if you guys have a pic of it that would be even better. thank
Old 06-25-2010, 11:58 AM
  #33
01hondagirl's Avatar
Icon2 Re: Changing Transmission Fluid (bemused)
Originally Posted by hondadude
When I learned to tie my shoelaces I didn't make fools of people that couldn't tie their shoelaces. [Albert Einstien]
There is a drain plug on the lower part of the trans that has a 3/8" square hole in it.
Remove that plug with a 3/8" drive ratchet, clean off the second gear clutch pak material from the magnet attached to the drain plug. Reinstall the drain plug then put in 3 qts of genuine honda trans fluid.
No doubt some simpleton will now jump in and SHOUT the 'book' calls for 2.8 qts of trans fluid, but I've been doing this for over 22 years and have NEVER seen a honda trans hurt by having .2 qts extra fluid in it.
Question: My Husband did remove, drain, reinstall drain plug and added 3 qts of honda trans fluid; don't think he cleaned magnet on drain plug; he drove and it started to shake; now won't go into gear; check engine light is now on; was working fine before hand. How can changing fluid make us lose transmission? Or do you think if we repeat a few more times it will help?
Old 09-08-2010, 07:50 AM
  #34
donnie brook's Avatar
Default Re: Changing Transmission Fluid
can anyone tell me what size washer i should get to replace the old one when i do an ATF change? 1990 Accord EXR. and does the size change depending on the color of the car. mine is white.
Old 10-10-2010, 04:43 PM
  #35
chasbwdc's Avatar
When changing transmission fluid you are supposed to fill run and then drain several times. Do you use clean transmission fluid each time/
Old 10-10-2010, 04:55 PM
  #36
He knows where you live!
TheMuffinMan's Avatar
Is this a question?
Yes you want to use clean fluid each time. Why would you put dirty/used fluid in there to flush out the old fluid? The point of doing it is to free up any fluid/gunk that may have not come out the first time around.
Old 01-31-2011, 03:14 PM
  #37
joe zygmont's Avatar
i recommend automatic trans fluid drain nd refills to my customers with hondas every 15,000 because thats what i was told by acouple honda techs. also DONT use ANYTHING BUT GENUINE HONDA TRANS FLUID!!! even if it says its ok for use in hondas, dont use it unless its from honda. u will burn out the trans.
Old 08-06-2012, 02:06 PM
  #38
845154756's Avatar
I have a 99 civic ex. I changed the transmission fluid recently but after a few days it wanted to stay in the lower gear longer than it did before. After a week of this I changed the fluid again thinking I had not followed the instuctions correctly. Same results. It shifted perfectly for about 4 days then started hanging longer in each gear before changing.
Anyone have any suggestions for my issue?
Thanks
Old 08-06-2012, 07:14 PM
  #39
djkurious's Avatar
Thanks
Wrong forum
Old 08-06-2012, 08:15 PM
  #40
dlewis2583's Avatar
Old 12-29-2012, 04:31 PM
  #41
samljer's Avatar
Originally Posted by importfanatic17
If I were you, I would open the fill plug first. That way, you won't be screwed if you drain the fluid and can't open the plug to fill it up!
Non-issue, can always refill through the dipstick if that happens.
"as it did to me"
Since then ive just funneled fluid through the dipstick pipe. no issues.
Old 01-02-2013, 04:16 AM
  #42
H-T Order of Merit
TouringAccord's Avatar
"as it did to me"
not true, on a manual transmission there is no dipstick so it is an issue.
Old 01-07-2013, 08:01 AM
  #43
samljer's Avatar
Hmmm, my manual has one. I guess when you assumed ALL of them dont
you made a mistake. rofl.
Old 01-07-2013, 08:29 AM
  #44
Oh yeah? And you drive a 90-02 4cyl Honda Accord? With a manual transmission?
The automatic variant has a dipstick. The stock manual transmissions do not. You made a mistake. rofl.
'97 Accord EX 5spd
'97 Accord EX Auto
Old 01-07-2013, 06:53 PM
  #45
halfkoreanboy's Avatar
And i hope you are using Oem Honda Fluid on the 99-02 accord auto tranny, I had a 99 that i got with a bad trans. and they said they put in a used transmission when i got it and filled it with orilleys fluid it wouldnt go down the block with out slipping hardcore so i put dw-1 Honda fluid in 6 drain and refills 3 qts at a time and got 20,000 miles out of the broken trans. lol could have gone more but it got totaled And when you stop at a light it would bang down into gear lol But that Honda dw-1 fluid kept it strong and it seems like it needs a better trans. cooler because when the a/c fans were on it ran a whole lot better
Old 01-08-2013, 04:04 AM
  #46
H-T Order of Merit
LOL
Old 07-25-2013, 06:27 AM
  #47
apencking's Avatar
um hey im new and I know this is probably already answered but I need a quick answer before my poor litl car blows! Ive got a 99 accord coupe 5spd /160,000mi .e replaced everything axels, spark plugs, wires, dis.cap, now ive got cylinder 4 misfire (mechanic said probably bad exhaust valve) car is seriously lagging...cuts off randomly its a str8 so I can just jump start as im rolling lol also trans fluid..how do I put more...my dads a mechanic just don't have a lift...I need cheapest route!
Canucksfan101
02-02-2015 10:05 AM
northtexas
Honda Civic (2006 - 2015)
10
09-25-2013 09:29 PM
bmclean1
02-24-2011 08:03 PM
dan_g
27
10-05-2009 03:06 AM
baiwldrnner
Honda Civic (2001 - 2005)
07-18-2007 09:55 PM
Quick Reply: Changing Transmission Fluid
