oil drain plug is stripped out, help please!
Old 02-20-2002, 08:51 AM
ImprtTuner88's Avatar
Default oil drain plug is stripped out, help please!
ok, just got one hell of a deal, got a B16A longblock for $375 (it was taking up too much space in this guys garage, he wanted it out) just has one problem with it, the drain plug is stripped as well as the drain plug bolt, any guys ever retapped this bigger and just used a larger drain plug bolt? Or am I stuck with having to buy a new oil pan? Second question........this motor has sat in his garage for 6 months on a pallet under a tarp with no oil in it and nothing stuffed into the intake or exhaust runners........any ideas of some preventative maintance or something to look for when checking the motor over before filling her up with motor to make sure everything turns nicely? Thanks for all the help guys, you all are the best!
Old 02-20-2002, 08:56 AM
Spade's Avatar
Default Re: oil drain plug is stripped out, help please! (ImprtTuner88)
If you tap it bigger then you have to find a bigger plug (hassle)
IMO purchase a new oil pan.
Take it apart and clean every inch. Follow reassembly instructions including the use of cam lube. and other goodies used when rebuilding engines.
Old 02-20-2002, 09:58 AM
AutoboTxEK's Avatar
Default Re: oil drain plug is stripped out, help please! (Spade)
just get a new oil pan...
Old 02-20-2002, 10:18 AM
Default Re: oil drain plug is stripped out, help please! (AutoboTxEK)
that probobally is the best bet..........what would the cost of a OEM oil pan compare with that of a Moroso or something?
Old 02-20-2002, 10:42 AM
Spade's Avatar
Morso's go for like 300 bux.....funk that!!!
Old 02-20-2002, 10:59 AM
FifthGearOnline's Avatar
an OEM pan will be fine
Old 02-20-2002, 11:01 AM
poison's Avatar
Default Re: oil drain plug is stripped out, help please! (FifthGearOnline)
go moroso ;x
it'll be better in the long run....and u'll be thanking urself u got it
Old 02-20-2002, 12:43 PM
dogpile5's Avatar
Default Re: oil drain plug is stripped out, help please! (poison)
OEM oil pan. spend $$ on something else more vital to the swap.
Old 02-20-2002, 01:17 PM
samdawgsol's Avatar
use a pair of lockin pliers on the drain bolt, those things can grip anything, and give you more area to grip. I use tehm on bolts and stuff whenever i strip them. Then just go buy another plug, unless you cant even grip it with the plierx then i guess you have to get a oil pan.
Old 02-21-2002, 04:12 AM
Default Re: oil drain plug is stripped out, help please! (samdawgsol)
I have been told honda sells a kit to drill out the hole and retap it, I think I am going to try that route, wonder how much that kit costs?? hmmm...........
Old 02-21-2002, 02:23 PM
BARF1's Avatar
FROM HONDA ??
just get a new oil pan ...
[Modified by BAR-F1, 11:57 PM 2/21/2002]
WTFProtein
05-12-2010 04:08 AM
vannak_5415
10-06-2008 05:34 PM
SPEEDCORE
08-05-2003 08:05 PM
ShiftDown
07-30-2002 11:44 PM
ImprtTuner88
02-20-2002 09:51 AM
Quick Reply: oil drain plug is stripped out, help please!
